Question about Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature
I have cj500c intermatic wall timer and it controls a ceiling fan. sometimes when you turn it on or off the whole timer resets.
  • 583 Answers
Its the setting issue and it needs resetting.
every time you lose power, you have to reset a dozen clocks around the house which is a real pain since we lose power frequently. But with the battery backup in this unit, it never misses a beat and keeps all its programming so everything works perfectly when power is restored
As mentioned in the overview, the flip down door that accesses the control panel also acts as a manual override switch. So you just press it (it has good tactical feel so you know you pressed it) to turn the lights on or off. Very handy if you want to turn on the light or appliance manually or to test that everything's working.
The initial setting instructions can be a bit confusing. The small buttons and small display screen can add to the frustration. I would suggest downloading the instructions here and following them to a "t". Go to http://www.intermatic.com and follow the Product - Timer links to Indoor - In Wall timers and click on the link to Easy Set Guide.
this will help you.
thanks.
please do rate the solution.thank you for using fixya.
Posted on Jul 14, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Welcome to FixYa. Please let me know what exactly you are looking for. Do you want to know why does the timer reset when you turn it on?
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 19, 2009
Whole house fan
no-op means no operation.
Replace battery, and reset timer... if functionality is not restored, then replace timer
http://waterheatertimer.org/ST01C-program.html#battery
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 06, 2014 | Intermatic Hardware & Accessories
Self adjusting in wall timer
Timer is not known.
Copy following links to identify timer and download manual
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
In the manual, you will see directions for resetting timer.
If resetting does not work, then review timer programming carefully to make sure there are no conflicts in the programming such as overlapping days, or inconsistent am-pm, etc
Jun 13, 2012 | Intermatic & Self-Adjusting Wall Switch...
I do not have an instruction manual for the Intermatic E1400WC timer switch and I can't figure out how to program the on/off times.
Intermatic makes heavy duty Ei400 series 1HP 120V or 240V countdown timer that can be wired for single-pole and 3-way.
Open following link to identify Ei400 timer and download manual:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#Ei
Coundownt timers are used to control fans and lights that need to run certain length of time, and then turn off. For example bathroom fan or whole house attic fan
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Solar Intermatic Digital Wall Self...
Our Intermatic EI200W is 1 1/2 years old and it has stopped working the way it should. It turns on the fan unit, it runs for 5 seconds and shuts off, it can be re turned on but again it only lasts for 5...
The problem could be the Load and not the timer.
I discovered that if there is a problem on the circuit, that these electronic timers can malfunction.
Buy circuit analyzer from home center, test nearby receptacle that is on same circuit.
If there is a ground fault, for example in your light-fan-motor, you have to track this down with multimeter or some other testing device.
If the circuit is clean, and your electronic device has malfunctioned, then bad news: There are no repairs for in-wall electronic devices.
I test timers: 4-6% arrive defective. Many go bad first year or two. Some last quite a while.
Some programmable timers can be reset and the timer recovers.
Intermatic page below shows countdown timers.
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%20auto-off%20timers.aspx
Sample manual shows 1 year limited warranty for your product:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei200%20-%20english.ashx
If I can make a replacement suggestion:
Manual spring-wound countdown timer lasts for 10 years because it has no electronic parts.
I have three of these and they work without a problem even on circuits that have small ground faults.
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer, or any household problem.
Jan 05, 2011 | Intermatic EI200W Electronic Auto Shutoff...
I am installing the timer for a whole house fan. I hooked red up to load, black to hot and white to neutral per instructions...confirmed with meter....the timer does not seem to work..I can turn on and...
A) GE 15069 image at Amazon
http://www.amazon.com/60-minute-Automatic-Shut-Off-Timer-Switch/dp/B002DNAE7Q
15069 manual
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/In-Wall-15069-Manual-eng.pdf
Manual shows GE 15069 countdown timer is rated up to 1/2 horsepower
Whole house fan is likely 3/4 horsepower >> check nameplate on fan motor.
B) work around:
Hook timer up to a contactor/relay.
Timer turns on 120 volt, 7 watt contactor coil.
Contactor turns on fan motor
http://waterheatertimer.org/H230A.html
Square D contactor at Grainger
http://www.grainger.com/Grainger/SQUARE-D-Compact-Contactor-5B132?Pid=search
http://www.pexsupply.com/Furnas-Controls-45EG20AF-2-Pole-30-Amp-120V-Contactor
I buy these contactors at local HVAC supply for $15
add a comment if you need help wiring this device.
C) List below shows countdown timers with horsepower rating:
GE15088 countdown timer is rated 3/4 hp
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay
Intermatic spring wound countdown timers are rated for 2 horsepower
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
Woods spring-wound countdown timer says bath/ ceiling fans, but doesn't give horsepower
http://waterheatertimer.org/pdf/Wood-59700-series--spring-wound.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
Woods push-button countdown is 1/4 horsepower
http://www.amazon.com/Woods-59014-Decora-12-8-4-2-12-Hour/dp/B002C54GH4
Lutron MA-T51 countdown timer specifically says it cannot be used for motors, which says the electronics inside each device is Load specific
http://www.amazon.com/Lutron-MA-T51-WH-Maestro-Countdown-Timer/dp/B001EFV1DA
http://www.lutron.com/TechnicalDocumentLibrary/0301041A.pdf
Pass and Seymour RT1 countdown does not show rating for horsepower, so this timer will probably not work for fan motor
http://www.homedepot.com/Electrical/h_d1/N-5yc1vZ1xg8Zarcd/
Wattstopper RT50 at Grainger shows 1/6 horsepower rating
http://www.grainger.com/Grainger/WATT-STOPPER-Time-Switch-2HTE1?Pid=search
Dec 12, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Light turns off in the morning, but does not automatically turn on in the evening
Battery-operated Intermatic timers can develop problems.
1) Battery may need to be replaced.
http://waterheatertimer.org/ST01C-program.html#EJ500
2) Troubleshoot guide on manual says to 'reset and reprogram' timer if problems occur.
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
3) Timer comes with 1 year warranty and can just go bad.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Nov 21, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
I am installing a intilitech 7 day in wall timer replacing an old mechanical 12 hr timer. The load is a 1/4hp 2 speed attic fan. The original wiring had hot in hot out of the timer. This has hot in, hot...
Utilitec does not make a 2 speed timer.
http://waterheatertimer.org/Program-wire-Utilitech-LW60419.html
1) One possible option is a timer with NO and NC terminals like Intermatic-Grasslin FM1 series rated 1 HP. This example timer would have the motor running continually on either one speed or the other.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/grasslin/fm1%20series%20time%20switches.ashx
2) Inside a 2-speed motor are two separate windings.
Windings are loops of copper wire that cause the fan motor to rotate.
For 2-speed, each winding has to be connected to a different 'switch.'
For example, like a ceiling fan. You pull the chain once, and electricity flows to one winding. Pull the chain again, and the switch sends electricity to another winding.
3) The following wiring diagram shows ordinary on-off timer connected to 2-speed switch: This is the basic plan for Broan Nutone 2-speed switch timer, which might be the product you are replacing
http://blog.airscapefans.com/wp-content/uploads//timer_option1_1-1024x768.jpg
4) Nutone makes a 2-speed whole house fan timer.
http://www.nutone.com/PDF/InstallGuides/CFS2WHins89777.pdf
5) And open following Broan Nutone manual that show the two spped timer wiring
http://www.nutone.com/PDF/InstallGuides/CFS2ins57169.pdf
Jul 01, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Timer will not turn off
As last resort troubleshooting Intermatic battery-operated timers, replace battery and/or reset timer.
Manual has troubleshooting section.
Open following link for manuals and wiring for Intermatic timers.
http://waterheatertimer.org/Flipdown.html
May 27, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Is the GFCI frying my intermatic timer?
First off is the black wire feeding the gfci going to the brass colored screw? If so make sure the black wire coming out of the timer is attached to the brass screw on the gfci and the white colored wire is attached to the silver screw. If these are all connected properly it is possible that the fan isn't wired properly.
Aug 10, 2009 | Intermatic FF60MC Energy Controls -...
Ceiling fan controled by intermatic e1010/e102 doesn't come on
If you are getting heat on the timer it is time to replace it
Jul 28, 2009 | Hardware & Accessories
Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature Logo
77 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
