Samsung wb250f manual
Why is the camera memory full with only one picture on it?
SOURCE: Camera says "memory full," but there's no pictures...
I had this problem, I don't know how it happened. I have the samsung digimax s500, this is what I did. 1 press menu 2 go to 'setup' 3 scroll down to 'format' 4 click right and scroll down to 'yes' that fixed mine, good luck
Posted on Feb 21, 2007
jackboy
  • 2985 Answers
SOURCE: Memory Full
What size is the memory card. What picture size has the camera been set to? Check out your Manual for the images sizes viz a vis memory card capacity - and come back
Posted on Jul 13, 2007
fblock
  • 289 Answers
SOURCE: camera said memory full but I have memory card
You need to format the SD card before it will be used by the camera. Formatting instructions are in the manual.
Posted on Apr 27, 2009
  • 12 Answers
SOURCE: turn camera on and says memory full save to favorites .. no pictures in camera..using internal memory only
Hi.
Enter main menu, scroll down to "Setup Menu" and then navigate to "FORMAT". Simply format your internal or external memory, and thats it.
Posted on Jun 12, 2009
Obertelli
  • 3006 Answers
SOURCE: memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Posted on Oct 06, 2010
Takes a photo when touch screen is touched.
Check your Users Manual , All cameras set in different ways
Mar 15, 2015 | Samsung WB250F SMART Camera Cobalt Black
How do i transfer pictures from camera to computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Sep 16, 2014 | Samsung Cameras
Why does it keep saying memory full after I have only taken 6 pictures
You need to go to the store and buy Samsung S730 A-DATA 4GB SDHC Memory Card (Class 4)
It is worth about 8-20$. The memory card is used to save pictures. Here is an example: http://www.cellularfactory.com/camera/SAMSUNG/3/46100/
Apr 02, 2012 | Samsung Digimax S730 Digital Camera
Memory full ... when there are no pictures
Try refomatting the memory card. Basically this removes all data from the card and makes sure it is empty.
It sounds like you have copied the pictures to your computer but NOT told the camera to delete from the camera card as you do so.
Check your camera manuals for details.
Mar 28, 2010 | Samsung Cameras
Memory Full Error
You need to format the SD memory card using the camera format function. The manual should tell you how to do this. If you don't have the manual, you can download it from the samsung website.
Jul 05, 2007 | Samsung Digimax S700 Digital Camera
202 people viewed this question
k24674
jasbo
jasbo
