Question about CyberLink PowerDVD 6 Deluxe Full Version OEM for PC
Whenever i place a dvd in the dvd player it says i am to put in a code for activation
How do i enter the code from my samsung blue ray player,so i can watch youtube.with an account
Go to http:/youtube.com/activate and type in the code you see on your Samsung blue ray player. It will automatically activate your player.
Feb 03, 2015 | Samsung Televison & Video
What do I do about a wrong activation code?
You need to contact cyberlink support as your laptop has not been correctly registered. Did you have it online while installing it?
Customer Support CyberLink
Jul 04, 2014 | Toshiba Satellite Computers & Internet
When i put my dvd in the video a message comes up on my screen saying this dvd is unauthorised ot play.I got the dvd from america and its a region 1.can you help.
Your DVD is region code protected. Check the back panel of your DVD player, where the connectors are, and you will find the region code. If the region code of your player is not "1" then you cannot play the DVD.
However, the region code can be unlocked, if you provide me with the player's exact model number.
The region code sticker looks like this one of this:
Sep 18, 2009 | Televison & Video
No video pic/only sound..//cyberhome CH-dvd 300 player
Whenever you have audio and no picture, its always a good idea to make sure that Progressive Scan has not been activated accidently. Follow the instructions in your user manual to get out of Progressive Scan.
Apr 03, 2009 | Cyberhome CH-DVD 300 DVD Player
Dual XDVD710 Car Video Player
There isn't a code but there is a way when you wire it. DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 31, 2008 | Dual XDVD8181 Car Video Player
Heidy5050@hotmail.com
What code? Do you mean an unlock code? You'd probably have to go through the manufacturer for that. If you mean a code to allow DVD playback while moving, there isn't such a thing. To do that you have to wire it a certain way (which is easy).
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jul 27, 2008 | Audiovox VM9512 Car DVD Player
Player was put on progressive scan and has stop displaying any video
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
May 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Wrong disc?
for god sake, i want to talk to customer support... you guys don't even have a 1-800 number posted....disgusting.....I am very upset with your cheap product...i guess i won't be buying protron dvd players from now on.....Whenever I put a dvd, it keeps on saying wrond disc and makes a wierd sound....please solve my problem and also give me your customer support phone number
Nicky Patel
Oct 22, 2007 | Protron PD-800 DVD Player
CyberLink PowerDVD 6 Deluxe Full Version OEM for PC  Logo
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
