Question about Globe 12" Chefmate Economy Manual Slicer
Won't turn blade will not turn
My blade assembly broke. Can I get a new one for my Maxi 4000
replacement can be found on amazon, take a look here: Amazon com Vitamix blade assembly. I hope this was helpful. Cheers
Jan 16, 2013 | Vitamix Vita Mix Maxi 4000 Commercial...
The /blade doesn'treach the bosttom of the bowl what to do
If the blade is locking in correctly and not loose then that is how it is supposed to be. Remove blade and reseat it to be sure.
Jan 11, 2011 | KitchenAid Food Mixers
Blade will not turn
motor will hum but no blade turn if bottom seal worn and material leaks into shaft. Rekove drive head and try turning shaft if nio go dissasemble entire unit ,clean and service, replace seals
Sep 20, 2009 | Robot Coupe MP600 750 Watts Hand Mixer
Can't get the drive coupling off my Bosch Universal to replace it
I have had my Bosch Universal Mixer with the Blender and Food Processor Attachments since 2005, and I've loved it since the day I got it... that is, until the blender broke while my son was crushing ice to make slushies...
I figured out the "drive coupler" was stripped and needed replacing, but I couldn't figure out how to take apart the "blade assembly" which includes the "drive coupler" part...
My retailer, Pleasant Hill Grain, sent me the following email:
"I am not aware of any printed instructions for removing the old coupling and
replacing with the new. We recommend holding on to the blades with 1 hand and a
towel and using a needle nose pliers to unscrew the old coupling. You would put
the new coupling on in the same manner.
If these instructions do not work, I would suggest contacting the Service
Dept at Kitchen Resources in Utah. Their phone is 800-692-6724."
I still couldn't figure out how to take apart the blade assembly, so I did end up calling the distributor, Kitchen Resources...
Dave, the tech @ Kitchen Resources, answered my call on the first ring...
Once I explained my problem, he started giving me the same instructions Pleasant Hill Grain gave
me... I explained to him that holding the blades tightly wasn't working for me.
As it turned out, holding the blades did not secure the drive shaft because
the drive shaft was broken off INSIDE the blade assembly - which is why I could
not unscrew the old drive coupling part.
Dave's next question revealed the true issue at hand... my Blender Attachment has the blade assembly made of plastic - they switched to plastic
in 2005 because the metal assembly turned black in dishwashers.
Bosch just recently went back to using metal for this part - apparently the
plastic blade assembly didn't hold up.
Kitchen Resources - the U.S. Bosch Distributor - is sending me a new blade
assembly - no charge, he said it's covered under warranty. Woo Hoo!
Best of all, I hadn't yet purchased the replacement drive coupling part, because
I wanted to know how to go about replacing the part before ordering a new part.
With shipping this part would have been a $50+ repair - you have to love
customer service of that caliber!
[Aside: You really don't need to ever put this part in the dishwasher - wash
the inside with by putting hot water and perhaps a little dish detergent inside
the blender and turning it on - rinse the outside under the sink... no
dishwasher needed! ]
Mar 23, 2009 | Bosch MUM6610 Universal Series Stand Mixer
Blade is hitting the bowl and the screw will not turn anymore
Turn the screw to the right. It will only turn a quarter turn. If that doesn't help try to file a bit of metal off the bottom of the beater. If you find this solution helpful, please rate it. ricardok45
Jan 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Blade won't release from mixer
Try to push up while you turn the blade. Don't be afraiid to turn hard.
Dec 30, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Blades won't stay on mixer
if this is new then i would just take it back it may be faulty.
Oct 27, 2017 | Wolfgang Puck Food Mixers
Blades
The blades pull straight off the shaft. If you look closely you will see a small notch on the blade that fits a tab on the shaft. This keeps the blade turning at the same speed as the shaft.
Anyway, pulling straight down on the blade should get it off. You might try boiling the tip in water to soften whatever gunk is holding it on. Be careful you don't burn your fingers when trying to pull off the blade after boiling it.
Sep 21, 2007 | Bamix Mono Mixer
Globe 12" Chefmate Economy Manual Slicer Logo
24 people viewed this question
Top Globe Food Mixers Experts
Kevin K.
David Ellis Rhea
Gerald buhagiar
Gerald buhagiar
Are you a Globe Food Mixer Expert? Answer questions, earn points and help others
