Question about JBL MS8 MS Series Digital Processor
Please wait on display screen ms8
Display screen worked fine for 5 days now its locked at please wait
Why isn't my netflix working properly?
Netflix Customer Phone Number Shortest Wait Best Support
Phone Number
888-638-3549
Talk to a Human
Press 0 at each prompt.
Average Wait: 5 mins - 24 hours, 7 days
Phone Number
888-638-3549
Talk to a Human
Sep 12, 2014 | Netflix
In my nokia 6600 mobile phone bluetooth not working these days
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.
or try this(But it will fully format your phone)
Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2: Hard Format of Nokia Mobile Phone 1. Switch off your Phone 2. Now Press following key-*#7370# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3: Soft Reset of Nokia Mobile Phone 1. Switch off your Nokia phone 2. Now Press following key sequence *#7780# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Please Note: The formatting method will erase all of your Phone data. Please take a backup before you Format.
Dec 16, 2010 | Nokia 6600
After a hard reboot, my HTC G1 works fine, then locks up about 5 minutes later. I've tried both soft and hard rebooting. What's the next step?
Factory restoring is the next step. To do this, when booting the phone, you will need to hold the home button and power button as the phone is booting. Keep holding these even while the G1 screen is displayed. After about 30 seconds, the screen will change to a triangle. On the triangle screen, you will then wait approx. 5-10 seconds and then press the home and power buttons one more time. This will bring up an options menu that will let you wipe and restore your phone settings. As long as you have your gmail information in the phone, you will not lose your contacts.
Apr 10, 2010 | HTC G1
When I hold down remote lock or unlock button to set, horn doesn'
Setting can be accesed through the radio to change options. Follor the owners manual.
Feb 25, 2010 | 2005 Chevrolet Malibu
406 wont lock/unlock please help!!!
Switch ignition ON.Press and hold lock button for 10 sec.Switch ign.Off.Remove key from ign. switch.Wait 5 sec.Sinchronization procedure complete.Confirm sinchronization has been successful by locking,double locking and unlocking vehicle. Repeat abuve procedure to sinchronize any remaining key.Good luck
Nov 30, 2009 | 2005 Peugeot 405
My ipod displays charging please wait..... and wouldn't charge???
google it. also another thing is to try is plug it in and hole menu and center button until an apple turns up or until yoour omputer reconizes it
Jun 05, 2009 | Apple iPod classic MP3 Player
Watch Problem
Get the battery out of the watch and wait for a 5 minutes. Fit the battery back and reset the watch.
Do not forget to rate, please.
Feb 12, 2009 | Timex Watches
DVD locked in and door is not opened
might have stuck inside...u got to open up the system onlly
Apr 01, 2008 | LG RH177 DVD Recorder/HDD Recorder
Nokia 6085 has a blue screen
I have the same problem with my Nokia 6085 phone. was working fine and then it started glitching after a month the glitching display went blue. after 3 days it started working again but I had to power it off and on again and when I did that my display was gone again. I cant text. I know my phone and where everything is so I tryed to send a text but it will not work but I can make and get calls.
Mar 30, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
JBL MS8 MS Series Digital Processor Logo
69 people viewed this question
Top JBL GPS Experts
Are you a JBL GPS Expert? Answer questions, earn points and help others
