Question about The Children's Place Girls Led Silicone Watch - Purple -
Need to set time on a childrens place led silicone watch
    New Friend:
    Problem Solver:
This how I set my son's watch from TCP. Press the screen to turn the watch on, once the time is displayed press and hold the center just below the display area until the hour blinks, then press repeatedly until the hour is correct. Press and hold again to set minutes, etc.
Posted on Dec 24, 2014
  • Jessica Preston
    Jessica Preston Sep 14, 2015
    Thanks!! I have one happy daughter now! She was mad bc she had been telling her friends the wrong time at school!!
No instructions with 1095 transformers watch. How do you set time?
Guessing you press and hold the Mode Button and change with the other button. Press mode again to go to minutes. Press Mode again to set.
All the manuals are here
https://www.skmei-watch.com/index.php?route=information/information&information_id=33
I says here you can ask questions on the seller page. It should come with a manual.
Skmei 1095 Kids LED Digital Children Watch Cartoon Sports Watches Relogio...
video
Transformer watch by SKMEI
Dec 18, 2017 | Watches
How to set the time on a digital watch
Hi, you need to find the little black "set" button which is located on the right side of the watch between the two functioning buttons. its very little. Press it once with like a needle or a pen tip (because you cant reach it with your fingers). You can then set the time.
Jan 12, 2014 | Watches
Intercrew LED watch, model ic3905. How do I set time and date?
Setting intercrew led time and date - Fixya
www.fixya.com/support/t14276175-setting_intercrew_led_time_date
Sep 8, 2012 - setting intercrew led time and date no instructions to set time and date on LED Watch by INTERCREW - Watches question.
Intercrew LED - YouTube
? 1:57
https://www.youtube.com/watch?v=bR9oGWDTwxs
Jan 25, 2012 - Uploaded by CoolWatchDanmark
Review af et af vores meget popul?re LED-ure. Intercrew LED. ... ????????
Dec 24, 2013 | Watches
Gasket repair
I've used a toothpik wooden or like the dentist uses and clear form-a-gasket silicone and put that in place of the gasket. and assemble the watch.wipe off any excessive silicone (be care not to have any or as little excess as possible)and allow to dry and then make sure your watch operates correctly.
Oct 21, 2013 | Casio Watches
Replacement band
Contact MK for the band the replacement is not available aftermarket. It is a common problem with the silicone bands.
Oct 01, 2013 | Michael Kors MK5145 Watch
Instructions for Intercrew LED
Press A (Top Left) once
Press D (Bottom Right)
It should start flashing
Press B (Top Left) to adjust
Press D (Bottom left) to move thru time,date ect.
Sep 08, 2012 | Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
Silicon scientific atomic projection clock did no reset for daylight saving. Help
I have one of these, and look for the manual on the 'Net every time DST changes, and eventually figure it out. Here's how: (1) Hold down the ALM/SET button until you get past the alarm setting and you see 24H or 12H. (2) Step through the settings by pushing the ALM/SET button, changing each as desired by pressing the +/CYCLE button. Eventually you'll wind up with the time zone indication flashing (it's really tiny, and appears just below the time indication). Press the +/CYCLE until you get to the desired time zone. (3) After the screen quits flashing, press the -/DST button to get the desired setting. I hope this helps, and that I can find this post again next time change!
May 19, 2010 | Watches
Silicon Scientific Radio Controled Watch
how to change hour number for setting clock back
Feb 05, 2010 | Watches
Silicon radio control watch, what # is the eastern zone
It depends which way you are looking at- West or East.
5th time zone on West is for: Greenland, Canada, USA, Bahamas, Jamaica, Columbia, Peru.
On East: Russia, Kazakstan, Uzbekistan, Afghanistan, Pakistan, India, Maldives.
I just do not understand why you do need this. All radio controlled watches are receiving the signal from the place in country where watch is worn- in my case its Rugby in England.
Use your user manual to sort this out.
Dec 11, 2008 | Bulova Watch
The Children's Place Girls Led Silicone Watch - Purple - Logo
4,257 people viewed this question
Top The Children's Place Watches Experts
Ansel Alberto
Ansel Alberto
Are you a The Children's Place Watch Expert? Answer questions, earn points and help others
