Kriesler heat pump
Remote stopped working
3 Suggested Answers
  • 409 Answers
SOURCE: Kriesler Heat pump, we have just bought this home,
Set the thermostat to heat and raise the set temperature, the unit should take care of the rest.
Posted on Apr 18, 2010
maatmartin7
  • 1210 Answers
SOURCE: kriesler air conditioner remote does
Sometimes you have to remove the batteries from the remote. Then take a pocket knife and scrape the battery contacts inside the remote. This is where you also install new batteries. If that does not help, you will need to find someone who is good at soldering. This person will have to resolder the contacts on the eye of the remote. Most of the time it is the infared bulb or lcd at the end of the remote. You may even need to replace the lcd of the remote. I have repaired a few of these, as they were dropped. Thanks for asking!
Posted on Mar 21, 2011
Problem with jandy rs 4. Pool heat pump Is running. We didn't turn it on and the heat pump light on the control panel is not lit
Does your pool gave an attached spa?
IF it does have a spa, dies it also have a spa side remote?
If so the first step would be to unplug the spa side remote from the back of the board.
If the issue stops then you need a new spa side remote if it persists then it nah be be main circuit board or relay for the heat pump.
Nov 01, 2014 | Jandy AquaLink RS 4 P or S OneTouch Pool...
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
Heater won't get hot,flushed system,changed thermostat and water pump,heat worked a few days and stopped again
You probably have a weak battery in your remote. Replace with a new battery and try again.
Jan 15, 2014 | Cars & Trucks
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
Where can i get a remote control for a Kriesler air conditioner?
Please try with authorized dealer near to your shelter.
You can avail the details from company web site.
Dec 16, 2010 | Panasonic CW-XC243HU Air Conditioner
Pump over heats and stops running
any time a pump over heats and stops running is
A. the pump is bad.
B. the float is stuck and the pump is causing it self to run and run until it over heats and shuts down.
C. Something is clogged in the pump and restricting the flow and causing the pump to work harder and over heat and shut down.
D. the check valve is bad, stuck closed, something stuck in check vavle.
May 18, 2010 | Flotec Plumbing
Kriesler Heat pump, we have just bought this home, no instructions to heat pump, don't know how to warm up the rooms using the heat pump
Apr 17, 2010 | Heating & Cooling
Dropped remote and broke it so brought universal remote and friend got it going. Then week later stopped working so changed batteries (even though new ones were already used) but it started working...
it depends on how many times and how long it sits on direct heat,that is never recommended for electronics,it could have a burnt board,i suggest to buy a new one,dont lay it on any heat source
Jan 08, 2010 | Televison & Video
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
