Question about Kodak PROFESSIONAL 9810 Thermal Photo Printer
Tarry new ribbon incorrect ribbon error
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
Jan 03, 2016 | Printronix Office Equipment & Supplies
My kodak says incorrect ribbon and even though I've tried 3 ribbons i still get the same error.
new ribbon is not supportive on kodak 6850 so please anybody have a tools to update printer?
Mar 07, 2011 | Kodak 6800 Thermal Photo Printer
I have a Fargo DTC550 Printer and laminator which i just got yesterday and after setting it up by carefully following every instruction in the manual it keeps displaying "Wrong Ribbon Installed" "An...
in windows 7 go to start>Devices and Printers> Right click on DTC550 and go to printing preferences then click the Device Options tab and click auto ribbon select
Oct 20, 2010 | Office Equipment & Supplies
I have a new iron which I dearly love. It all of sudden began spittin dark tarry substance How do I clean It?
The black tarry substance is lime residue, which often comes out when the iron is not completely hot. One option is to use filtered or distilled water in the iron instead of tap water, but that will not instantly clean it, but it may decrease the problem in the future.
It's probably a good idea to flush it through by spraying/steaming with the new filtered water. You could even add a few drops of vinegar to the filtered water to assist cleaning the iron. However, don't use that vinegar water to iron the clothes, as it may stain. replace the water (with fresh filtered water) and lightly flush (spray and steam a few times).
I hope this has helped!
Aug 12, 2010 | Polaroid 600 Film Camera
Error 80029725 ps3
If you've had this unit apart recently open it back up and make sure ALL ribbon cables and wiring harnesses are slotted correctly. I had an error code problem and it turned to be an incorrectly seated ribbon cable.
If that doesn't fix the problem try formatting the drive, it could be a corrupt file on the hard disk. Make sure you back up anything you want to save on a flash drive first.
Apr 17, 2010 | Sony PlayStation 3 40GB System
Kenmore model number 95781000 displays error code E1 F1. Occurred after power outage. Clock & oven do not work. Surface works. From what I'm reading, it's a better decision to buy a new oven than pay...
Try this first! The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. A fuse 2. Control panel 3. Relay panel. Good luck!!!
Oct 28, 2009 | Kenmore Ovens
2265+ ribbon error
The Ribbon can only be installed correctly as you have to lower a bar after to allow the printer to start if it was in incorrectly this arm would not lower and you would get no printing.
Instruction manual will explain better
http://www.softwaredriverdownload.com/download.php?file=964rxfbkkrZnRwOi8vZnRwLnRhbGx5Z2VuaWNvbS5jb20vcHViL2dlbmljb20vZG9jcy90YWxseS9zZXJpYWwvdDIyODAvMDYzMDUwYV9vbTIyNjVfZ2IucGRm
Dec 27, 2008 | Tally T2265 Dot Matrix Printer 917402
Error code 754
It's very possible you are not installing the ribbon properly.
When loading a new ribbon on a Monarch printer, you must save the plastic ribbon core (it's butter yellow in color) from the previous roll of ribbon. The core is what the ribbon is wound up on.
Do not throw away this plastic core - you need it for the next roll of ribbon you load!
You have to move this now empty core from the back ribbon spindle and slide it on the front ribbon spindle. You then load the new ribbon on the back spindle and attach the ribbon end to the empty plastic ribbon core on the front spindle.
You CAN NOT just tape the ribbon to the front spindle. You must have an empty ribbon core to attach the new ribbon to. The printer will give a 754 error unless you have two plastic cores on the two spindles. It can also give a 754 error if the ribbon is not loaded properly, and also if you have a bad motherboard. There are no ribbon sensors, so that's never going to be a problem...
Jul 28, 2008 | Paxar Monarch 9850 Thermal Printer
Kodak PROFESSIONAL 9810 Thermal Photo Printer Logo
29 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
