Question about Mongoose Exile 26 Men's Full-Suspension Mountain Bike
Gears loose will not shift
Gears are loose and will not shift
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
    • 1Remove the bolts and nuts that secure the center console around the gear shifter with a 1/4-inch drive ratchet, a metric socket and a Phillips head screwdriver. This will expose the rubber boot. Pull back any carpet as needed to make room for the rubber boot to be pulled over the gear shifter.
    • 2 Turn the gear shifter knob counterclockwise to remove it from the top of the gear shifter. Pull the rubber boot over the gear shifter and place it on the floorboard.
    • Sponsored Links
    • 3 Loosen and remove the retaining bolts at the base of the gear shifter with the ratchet and a metric socket.
    • 4 Remove the gear shifter retaining ring with the pliers. Once the retaining ring is removed, you will now be able to pull the gear shifter lever straight up through the console hole. Inspect the bushing on the pivoted area at the bottom of the gear shifter lever. Remove all of the damaged bushing from the bottom of the gear shifter lever with the pliers.
    • 5 Place the new bushing over the pivotal ball end of the gear shifter lever. Hold the gear lever with one hand and twist the bushing onto the ball end with your other hand until the bushing locks in place.
    • 6 Reverse the same steps as outlined above to reinstall the gear shifter assembly and the center console assembly. Make sure that all of the retaining nuts and bolts are tight.
Read more : http://www.ehow.com/how_8389358_tighten-loose-gear-shift.html
Posted on Apr 03, 2015
My cars shifter is not working properly it wont catch gears and im driving in Neutral in all other gears it grinds
The rod that goes to the box is loose or not inline how it should be, so when your moving gears in the car its not quite going in at the box right, could be engine mount broken or just really loose or at the selector end loose
Oct 04, 2014 | 1998 Honda Accord
Wont go into park
Is the column shift lever loose or does it feel normal shifting through gears? If loose, check linkage between shift lever and transmission located under driver door side of transmission.
Aug 01, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
Shifter hard to move thru gears cables are good and free when disconnected hear squeak when shifting
first i would contact ford dealershift to see if any recalls with this problem...The transmission on the 2002 Ford Focus has been having problems shifting gears,The linkage inside the transmission suffers from premature wear, causing difficulty in switching or shifting gears. The transmission bands that wrap around each gear to hold the gears in place are becoming loose, causing the gears to shift harshly. Both problems have been the biggest culprit when the Ford Focus transmission experiences problems shifting gears. The only correction for this shifting problems is to have the transmission replaced or rebuilt.
Read more: http://www.ehow.com/list_7328764_2002-focus-transmission-problems.html#ixzz347AiEF2K
Jun 08, 2014 | 2002 Ford SVT Focus
Changing gears
Hi, Dave and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return spring weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r3-forums.com/forum/522-drivetrain/14065-shifting-issues-thread-problems-your-shifts.html
Gear shifting problem
OEM parts for Yamaha
Gears stuck up shifting
My Motorcycle can shift up or down anymore Is the problem bent shift lever
Mar 09, 2014 | Yamaha Motorcycles
2000 sable- can't shift out of park. shifter glides and needle on dash moves there's no gears shifting. is the transmission blown?
Not likely a blown transmission. More of a shifter cable issue. There is an adjustment nut on the ****** end. It could be loose or missing. If the nut is fine you have a broken cable.
May 19, 2012 | 2000 Mercury Sable
1991 Kawasaki ZZR 250 will not upshift
Hi, Johnknox45 and the usual suspects are:
1. Improper clutch adjustment or not disengaging.
6. Shift return springs weak or broken.
11. Shift lever loose on the shift shaft.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
won shift up to 2nd
http://kawasakiworld.com/zx-12r/46572-won-t-change-gears.html Kawasaki ZZ R250 Service Manual Page 2
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Sep 16, 2011 | 1991 kawasaki ZZR 250
Standard shift gear slippage
check linkages at gearbox.if these are loose inproper engagement can occur causing gears to drop out
Feb 27, 2010 | 2001 Chevrolet S-10
Gears shifter will not engage the gears i think it is the trans linkage where is it located?
it's a cable under car . may be just loose connections. floor shift?
column shift?
check under hood first on driver side where transmision is. look for loose fasteners. then you might have to remove console for floor shift or plastic shrouds if column shift.
Dec 12, 2009 | 1999 Mercury Sable
Automatic transmission won't shift into higher gears.
It is likely a bad input shaft or output shaft speed sensor. But have the tcm scanned for codes.
Mar 14, 2009 | 2002 Chrysler PT Cruiser
Mongoose Exile 26 Men's Full-Suspension Mountain Bike Logo
253 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
