Question about Canon Office Equipment & Supplies
Error e 000004-0103 canon 5050
Error e000004-0103 canon 5050
leethedeuce
  • 4472 Answers
SOURCE: I have 2 error codes
First of all how long have you owned the printer and how long have you been recieving these errors. Once I have more information I can assist you further.
Thanks,
Lee
Posted on Sep 25, 2008
  • 3 Answers
SOURCE: E000004-0004 canon
dirty sensor that the fuser unit activates needs cleaning. Remove the vertical paper feed assembly - you'll see a black sensor arm that "breaks" a photo interupter and closes 2 micro switches. Its the photo interupter thats dirty.
Posted on Mar 19, 2010
muleskinner2
  • 270 Answers
SOURCE: canon ir 5055 has an
This is a fixing error code - there is too much temperature difference detected by the thermistors. Mostly a error reset will take care of the problem. You have to get into service mode first. Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Then copier, function, clear, err, then OK. This clears the error code from the copier. Then power cycle the copier and the copier should be operational. If this doesn't work then you will have to have a technician fix it. DO NOT keep resetting the code. There is something wrong with the copier that needs to be taken care before major damage is done to the copier. Good Luck
Posted on Dec 09, 2010
  • 525 Answers
SOURCE: my canon IR 3100 CN
E004
The main thermistor (TH1) has an open circuit or has poor contact. The sub thermistor (TH2) has an open circuit or
has poor contact. The thermal switch (TGP1) has an open circuit. The main heater (H1)/sub heater (H2) has an open
circuit. The AC driver PCB is faulty. The DC controller PCB is faulty.
E004 0001 protection circuit error of the fixing unit
Description: A short-circuit is detected in the triac (for 1 sec or more continuously) while the heater remains off (hardware detection) for 40 msec continuously.
Remedy: Turn off and then on the main power supply.
Remarks: fixing assembly triac malfunction/13V power supply error
Posted on Feb 12, 2011
vinuthna
  • 21 Answers
SOURCE: In canon 6570 when machine
hi this is srinivas
sir
canon 6570 when machine is switch ON error E000004-0103 and sometimes E000004-010 appears , what is the reason?pls giv me a solution.
thank u
Posted on May 20, 2011
ERROR E000004-0401 ON CANON C4080i WHAT DOES THIS MEAN
Code
E000004
Description
Fixing temperature abnormal rise
The temperature detected by the main thermistor does not rise to the specified value during startup control.
Remedy
1.Go through the following to clear the error: CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power. 2.Check connection of the Connectors (Thermistor Connector and AC Connector). 3.Replace the Fixing Main Thermistor (Film Unit). 4.Replace the Fixing Assembly. 5.Replace the DC Controller PCB (PCB4).
Sep 28, 2016 | Canon Office Equipment & Supplies
E000004-0010 error on my canon ir 5075
That means induction heater is faulty (insufficient current) and needs to be replaced.
Dont forget to clear error log after the replacement.
(copier>fnction>err>clear)
Nov 03, 2015 | Canon ImageRunner 5075 Copier : IR 5075
I have an error on the canon IRC3580ne e000004-0000. what should I do?
The DC Control Board maybe faulty. Have a qualified Technician look at this . Certain tests need to be performed and applied to rule out any other conflict.
I hope this helps, Steve
Sep 03, 2015 | Canon Office Equipment & Supplies
My canon iR c5185i displays error E000004-0401 please help me he solution
This is a fuser unit error, if powering off & on the machine the error doesn't clear then you will need to have the fuser unit replaced.
Aug 25, 2014 | Canon Ir-c5185i With Feed, Fax, Finisher,...
E000004-0101
When there is a short-circuit detection error in the halogen heater (ASIC detection)
Check the connection of the J114 jack of the AC driver PCB, and replace the AC driver PCB (triac short).
Replace the Pressure heater.
Replace the Fixing unit.
Nov 14, 2013 | Canon irc5185i
How to remove error code (E000004-0010)from canon iR-6570 photocopier?
gmana ya cara benerin error e000004-0010 pada mesin canon ir6570
Jul 07, 2011 | Canon Office Equipment & Supplies
In canon 6570 when machine is switch ON error E000004-0106 and sometimes E000004-010 appears , what is the reason?
hi this is srinivas
sir
thank u
Sep 28, 2010 | Canon IMAGERUNNER 6570 Copier
E000004-0004 canon
Mar 04, 2010 | Canon imageRUNNER C3200 Copier
Error canon 3220 E000004-0004
try cleaning the photointerrupter at the behind of left top delivery ***'y
Error message: E000004-0401
Probably the copier is iR C5185i
- E004 = Fixing unit protection circuit trouble
-  0401 = Check the connection of the connectors of the relay PCB, the IH power supply, the fixing thermoswitch, and replace the fixing unit (fixing
thermoswitch OFF), the relay PCB, and the IH power PCB (blowout of the
FU261).
In the service mode, clear the error by selecting COPIER > FUNCTION >
CLEAR > ERR.
You need a canon technician to resolve this problem.
Sep 25, 2009 | Canon Office Equipment & Supplies
162 people viewed this question
old marine
old marine
