Question about Golds Gym Trainer 410 Treadmill
Dead when new
New treadmill. Console completely dead, appears there is power to the bottom circuit board as red light is on. No beeps, no display, no nothing.
Nordic T20 Works for 25 minutes then stop working.Circuit board led comes on, but no consol power and no function at all. I do not have circuit diagram to fault find. Thank you!
Hi There, well, it sounds like your motor control board is failing due aging capacitors. Using the unit like this can lead to complete failure and possibly costlier repairs. You can find repairs and refurbs for treadmills by emailing gregATbuyfitnessrepairpartsDOTcom as well as for additional help. There is a power supply circuit on the control board that provides power to your console, if your console goes dead, as in no lights or beeps, the power supply is failing when warmed up. Good Luck!
Feb 07, 2016 | Exercise & Fitness
Reebok vista treadmill
This type of treadmills seem to have high probability of failure if you use the emergency cutoff switch instead of the power switch at the bottom.
My guess is by yanking the red magnetic safety switch, the induced current put a heavy load on the central controller circuitry, and over the time it damages the IC chips on that board.
There's a border-line failure phase before the controller goes completely dead, I realized this and stopped using the safety switch, it hasn't had any issue ever since.
Aug 06, 2013 | Reebok Vista Treadmill - RBTL13305
My new visions t9550 treadmill will not calibrate. it completes the speed calibration but treadmill will not elivate therefor fails calibration. what do i do?
Step 1:
follow this steps for troubleshooting and fix it. God bless you
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
Step 2:
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP for elevation Motor. You must clean contact of the Relay with Special Spray(Radio Schack).
With this you must fix it.
Step 3:
Try this again. and fix it.b) LUBE the gear motor, shaft and turn the POT a little and see if the motor get RPM.
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in).
Jan 07, 2013 | Vision Fitness T9550 Folding Treadmill
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
My New Balance 1400 treadmill recently stopped working. There is power going to the motor. The lights are on but there is no power to the display. nothing lights up and none of eh controls work. The...
It sound like either the wire harness that goes to upper console is bad or the Motor Control Board that has the 5v or 12v is missing. Here is the bad news New Balance is out of the Treadmill business and do not carry these items anymore. Their might be one other thing you might try is that if this unit was not maintain as owner's manual suggests, then the fuse may have open up. You must open the motor shroud locate motor control board find the fuse, if you have a multi meter check continuity of the fuse if open replace it with the same value ( maybe 15amps). Plug unit in if the display returns then proceed to do the prescribe maintenance in owner's hopefully that the belt and deck was not damaged when it went dead.
Good Luck!!
Max
May 09, 2011 | New Balance 1400 Treadmill
I have a Schwinn 815 treadmill. Today, during the middle of a workout, it stopped dead. The console display has no lights on. The only light that is on is the power switch light. Other than that,...
it sounds like the problem could be the wire from the console down to the motor control board has come undone or partly undone. you need to take the console off and see if the wires are conected properly. if this isnt the problem then the console might have fried somehow, possible from the same reason, the wires came disconnected and shorted out on something.
Sep 05, 2010 | Sport & Outdoor - Others
C2155 treadmill 1 1/2 yrs old, Nordic track. Panel lights up when the key is attached, beeps a triple beep sound fast about every 15 seconds? Keeps beeping when any of the buttons are pushed and won't...
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Jun 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
My dynamix treadmill the red power light comes on but the circiut board not powering up
I suggest checking your power plug then check or reset the circuit breaker or fuse holder on the treadmill next to the cord if that ok and the unit is still dead. Unplug unit the remove motor shroud and if you own a multi meter start checking the AC all the way to the lower board and see where the Ac is missing.
If the Voltage is good to the board then check DC Out put going the console wire harness should have 5v or 12v DC depending on model if missing then replace lower board, if present, then check the continuity of wire harness if bad replace harness. If good upper console needs to be replaced
May 25, 2010 | Exercise & Fitness
Overhead console (EVIC) seems dead
same problem. I finally solved it by buying a new circuit board with display from a junk yard for $35.00 and replaced it. they let me try it out there before i had to buy it. Works fine now.
Jan 20, 2009 | 2002 Jeep Grand Cherokee
Golds Gym Trainer 410 Treadmill Logo
37 people viewed this question
Top Golds Gym Exercise & Fitness Experts
Steven's...
Steven's...
Sock Puppet
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
