Question about Neff K3965XO Side by Side Refrigerator
Hi, hope someone can help. My NEFF K3965 X0 fridge freezer has been sitting in my garage turned off for 2 years, it has been plugged in since this morning and everything is working fine but the ice an
Problem with smell from fridge.
4 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Neff american fridge freezer, ice dispenser
Are your ice cubes to big or in the dispenser door not opening all the way both can be fixed adjust the flow timer on the ice maker or replace the door dispenser
Posted on Jul 27, 2008
imufo2
  • 3773 Answers
SOURCE: My Neff fridge freezer model
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 08, 2011
Testimonial: "Cheers mate, spot on, freezer working a treat with no leaks...yeah"
machinetech7
  • 1344 Answers
SOURCE: Neff Fridge Freezer K3965 Freezer is working but the fridge is not
This is either a defrost problem or the evaporator fan is not running. The way to check is to open the freezer and do two things. Listen to see if the fan is running, if not and you hear the compressor in the back going then the fan is the problem. If the fan is running then look at the freezer wall and see if it is covered in frost. If so, you have a defrost system failure and either the timer, bi-metal or the defrost heater has gone bad.
Posted on Sep 05, 2012
I have a Neff fridge and Freezer Model K4204x6GB03. The fridge is getting very cold and building ICe on the back wall of fridge and too much Ice on the bottom of the fridge under the vegetable tray
First, try turning down the temperature control on the fridge incrementally and see if that gradually over time helps. If not, you may need to unplug the fridge for 15 or so minutes, hope it will recycle and then plug it back up, setting the control to what would be normally considered to be a moderate setting. If that fails, call a fridge repairman who you trust, , ,
Jul 28, 2017 | Neff Refrigerators
Neff K3965 side-by-side American: Freezer works but Fridge doesn't any more, 3 days after defrost
Can you remove the freezer rear panel again and take some photos of the frost pattern so I may see what is stopping the cold airflow to the fresh food section?I'm here on Fixya if you have questions
Contact Me Here
Appliance 911 Sea Breeze
Nov 23, 2015 | Neff Refrigerators
Fridge freezer tripping rcd
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Apr 21, 2014 | Refrigerators
Sep 05, 2012 | Neff K3965XO Side by Side Refrigerator
My Neff fridge freezer model K3965 is leaking - Puddles of water are appearing underneath and ice is accumilating at bottom off freezer. I have looked inside and can't see a leak but ocasionly can...
Leo Ponder
imufo2
Aug 08, 2011 | Neff K3965XO Side by Side Refrigerator
Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Feb 04, 2010 | Refrigerators
Neff K9724 Fridge Freezer with water in the fridge drawers
sounds like a thermastat problem or maybe your drain away hole is blocked
Apr 25, 2009 | Neff K9724X4GB
GE Fridege TBX18J MS not getting cold
hi is the fan motor going in the freezer. if so how long has it been plugged in if more than 24 hrs and the fan is going. it could be that because it sat for 10 years the lines that go inside could have rusted out. so if this is the case its scrap sorry. the appliance doc.
Oct 16, 2008 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Dec 11, 2007 | Refrigerators
Neff K3965XO Side by Side Refrigerator Logo
106 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
