Question about Incredibowl i420 Repair Kit
Microwave will not heat up when turned on
Put food in microwave,set time for 3 min,press start,at the end of 3 min,food still cold.
    Master:
  • 448 Answers
You need a new microwave.
Posted on Aug 28, 2014
How can I get my microwave to actually heat when everything else (cook time, power level, clock, etc., are set and seem to be running?
Sounds like the MW Emitter is not working or the wave guide is disconnected. If it is the wave guide then you can fix it yourself if you take the rear cover off. It is the pipe, which in cross section is quite rectangle shaped with rounded corners. It should be connected to the emitter at one end and the opaque guide cover at the other with no breaks. If the emitter is faulty then seek professional help.
Oct 19, 2014 | Hamilton Beach 1.1 cu ft Digital Microwave...
I tried to reheat food and didn't get any results. Could I have ruined it by turning it on without food?
well if you keep on running your microwave without any thing in it then yes! it burns out the magnatron
(thats the bit the heat come from) and when there burned out its a dust bin jod as there very pricy to by and its not a smart thing to do trying to fit a new one by yourself,, you stand a very good chance of just killing yourself first,,to test your microwave opn the door put inside a cup of cold water and turn on the microwave for 3 mins on full power, the water should be boiling by then,,,dont put anything in the hot water like milk or it could explode in your face! just tip it away
Jan 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
GE JVM1870SF02 - not heating up anything!!
I had the same problem with mine, and discovered, somehow, that when I manually turned on the "vent fan", the microwave worked fine. A bit of a pain, but it heated up the food when it hadn't been prior to the vent fan being on. Can't understand why it solved it, but it's been working like that for about a year now. When I forget to turn on the vent fan though, the food is just as cold as when I put it in.
Jul 28, 2008 | GE XL1800 1100 Watts Microwave Oven
Turns on by itself and turntable does not rotate
You may have a control board issue. Thank God for safety switches.
This is a problem that an integrated circuit tech. can repair, but it may be costly.
Decide how much you want to put into this oven vs. buying a new one.
Contact me once you decide and I can help you find a service center.
Thank you,
Dave E. (Illeagle)
May 30, 2008 | Sanyo EM-S8000 Microwave Oven
Everything works...Except for actually heating the food
It has a bad magnetron. This is the tube that provides the microwaves to heat the food. Not too easy to replace yourself but it can be done. Cost of magnetron is probably less than $50 or $60.
Dec 14, 2007 | Frigidaire PLMV168 Microwave Oven
Please help....It was just like a "Frankenstein" movie.
Normally that aarcing is due to food particles or grease trapped in the waveguide. It will arc over and over until it is removed. The other, worse possibility is that the stirrer or magnetron has failed. If it'sd still under warranty, I would call the nearest Sears store for service. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://www3.sears.com (the 3 is correct)
May 07, 2007 | Kenmore 62702 Microwave Oven
Incredibowl i420 Repair Kit Logo
44 people viewed this question
Top Incred-i-bowl Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Incred-i-bowl Vehicle Part and Accessory Expert? Answer questions, earn points and help others
