Question about Transmission & Drivetrain for Ford Transit Connect
1986 ford truck transmission shifts hard. does not slip what causes this?
It shifts hard and late
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Automatic or 5 speed
Posted on Sep 06, 2014
My 1999 ford ranger shifts hard from 2nd to 3rd gear what is the problem I recently changed fluid and filter but shifts hard !
Auto Trans not shifting correctly from 2nd to 3rd - Ford Explorer ...
www.explorerforum.com > ... > Under the Hood
May 8, 2004 - 19 posts - ‎9 authors
Auto Trans not shifting correctly from 2nd to 3rd Under the Hood. ... Become an EliteExplorer. Lithuania. 1999 5.0. Join Date: Jun 2003. Posts: 107 ... When this happens, the transmission will skip to the next gear like you said.
Transmission Harsh shifting - YouTube
? 3:59
https://www.youtube.com/watch?v=aAoiL4vR8Qw
Jan 13, 2013 - Uploaded by James Burns
... Doctor, explores the causes of harsh shifting in automatic transmissions. ... Early diagnosis is important to ...
Hard Tranny Shift between 2nd & 3rd - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Feb 24, 2012 - Hard Tranny Shift between 2nd & 3rd Super Duty & Heavy Duty. ... I just got a new to me 99 f250 5.4 V8 SD XLT 4x4 Auto Trans longbox 118k miles. ... it out and said it was solid except for a hard shift between 2nd and 3rd gears. ..... Hard shift between 2nd and 3rd, Brenda Lamka, Explorer, Sport Trac, ... hard shift 2nd to third gear only 4r100
Dec 26, 2012
hard shift into 3rd
Nov 4, 2009
4r55e 5r55e Ranger / Explorer Transmission Problems - CLICK ...
Mar 15, 2007
00 Expedition trans shifts late and hard
Jan 01, 2016 | Ford Cars & Trucks
What will cause prolong shifting
Transmission shifting hard, delayed, slipping, could be a simple as changing the fluid and filter, to a sensor being bad or a shift solenoid being bad, or it could be simple bad wiring to trans or even dirty connections. See if you can pull the codes for the trans, it should give you an idea of what's going on. If you're not comfortable with this, then I'd suggest taking it to a professional, better to pay a few hundred than letting it burn up and paying thousands
Oct 27, 2015 | Cars & Trucks
My 1986 ford f150 4x4 shifts in gear rough at times but runs smoth
Shifting rough, as in, when you put it in reverse or drive it hits hard? Shutters? Slips? Time for a rebuild or get a good replacement.
Mar 07, 2015 | Ford Cars & Trucks
Why is my 1986 delta 88 shifting hard
There are many causes for this symptom.
Main suspects include:
worn out transmission
old fluid needs changed
valve body is dirty or clogged transmission filter
worn transmission or engine mounts
wrong transmission fluid added at top-up
shift solenoid broken
Dec 20, 2014 | 1986 Oldsmobile Delta 88
Ordered a speed sensor for my cadillac catera, I have had some slipping in the transmission and wanted to know if changing the sensor will possibly stop the problem in the transmission.
That all depends on what is causing the transmission to slip. Faulty speed sensors normally do not cause slipping. It can cause erratic, hard, or late shifting, but slipping is not usually included in that. If you want to know what is causing your transmission to slip, the place to start would be to scan your onboard computer system for fault codes and then properly diagnose the codes that are retrieved. Please note that fault codes NEVER tell you what parts to replace, they only tell you which of the many systems monitored by the computer are operating outside their designed range.
Please also review this article:
What Else Could Be Wrong?
Jul 12, 2011 | 2000 Cadillac Catera
Transmission
TRANSMISSION PROBLEMS WILL CAUSE CAR NOT TO MOVE IN ANY FORWARD GEARS. SOME TIMES TRANSMISSION WILL SLIP REAL BAD CAUSING EARLY + LATE SHIFTS.MOST TIME YOU WONT HAVE NO REVERSE ALSO.
Jul 31, 2010 | 2002 Oldsmobile Aurora
2003 ford taurus transmission light freeway
you'll need to get it diagn., it can be as simple as a "VSS" sensor, or a transmission, check the fluid and if BURNT, your looking at a trans.....GL....
Jul 04, 2009 | 2001 Ford Taurus
I just change the tranny becuase after driving an 1hr & Half the shift are hard ,after changing it ,it dose the same. i change the mount on it . it doesn't shift as hard but it dose the same what can...
You need to get someone to do a code-read with a transmission capable scanner (transmission shop) You probably have a bad EPC (electronic pressure control) causing the transmission to slip, therefore setting a p1811 code (max adapt/long shift) which will max out the line pressure making your shifts very firm (but stopping the slipping/delayed shifts...this is a fail safe mode designed to keep your transmission from slipping until you address the underlying cause)
Jun 10, 2009 | 1999 Oldsmobile Intrigue
Tranny slips in reverse
Reverse clutches are burnt. Clutch material is getting into valve body causing late shifts since valves can't move. transmisison will have to be overhauled. wish i had better news. sorry
May 01, 2009 | 1991 Mercedes-Benz E-Class
Transmission & Drivetrain for Ford Transit Connect Logo
62 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
