Question about Sanyo DS24425 24" TV
Sanyo DP58D33 has no picture but has audio - Sanyo DS24425 24" TV
  • 39 Answers
This can be from your main board or your power supply unit. To test which one is bad simply try putting your volume up or down while the TV is on. If the volume changes it is most likely your power supply unit, If nothing happens then it is most likely your main unit. Both are available here: 1LG4B10Y11900 Z7GB Sanyo Power Supply Unit for DP58D33 1LG4B10Y117000 Z7GB Sanyo Main Board for DP58D33
Posted on Jan 18, 2015
  • Sanyo Master
  • 1,208 Answers
If this is a standard CRT TV. The problem may be minor. You will have resolder the horizontal transformer (not the flyback transformer, although you may resolder this as well). You will also need to resolder the vertical IC. Do not over solder as to short pins here. And, if I remember from these older Sanyos...there may be a standing resistor or two (2 watts I think). This resistor needs resoldered. In any case inspect the board for any bad solder grounds. These will include the cracked rings on all transistors, capacitors, ICs etc. Also resolder the small board attached to the CRT. Becareful when you pull out the board to rework it. You must discharge the picture tube. See discharging picture tube on "You Tube". Thanks for asking me. Matt of Martins TV Repair.
  • matt martin
    matt martin Jan 18, 2015
    My mistake. This is flat screen LCD. Parts Runner is correct. Sometimes the inverter board is self powered and needs replaced. In this case I think the power supply proveds all the voltage to the screen. I saw the board Parts Runner is telling you about. The high voltage inverters are in the power supply. Yes, Parts runner is correct. Thanks for listening...again. Matt of Martins TV.
  • matt martin
    It is the power supply, You have sound...Main board is good.
I have a Sanyo LED tv model DP58D33. It turns on and functions perfectly for awhile, then screen goes black but still has sound.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 09, 2017 | Sanyo Televison & Video
Sanyo DP58D33 tv. Powers on no picture but sound. Flashlight test shows picture need to know which part to replace none of the parts are called led driver
You need the back light ballast board. Some are separate, while some models incorporate them in the power supply board. Go here to find out what parts you need. TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 11, 2016 | Sanyo Televison & Video
SCREEN TURNS BLACK OFF AND ON. SOMETIMES STAYS ON FOR HOURS, NEXTIME SECONDS
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 12, 2016 | Sanyo DP58D33 58IN LED TEION Refurbished...
I HAV a 58 inch Sanyo tv DP58D33 and my screen is black but when I flash a flashlight in a dark room while is on I can see the TV displays. What should I change to fix problem
a model 58D33 is a LCD screen not to be confused with an LED tv , aas LCD tv displays use a std fluorescent tube for its back lite source and yes they do burn out eventually , unfortunately these tubes are not a user changeable item and tv needs to be disassembled to install a new one
Nov 13, 2015 | Sanyo Televison & Video
My sanyo 58 " model dp58d33 screen has picture but the screen is l8ke flashing flickering whats the problem and fix
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 20, 2015 | Sanyo Televison & Video
Dp58d33 no sound or picture
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 06, 2014 | Sanyo Televison & Video
Blue screen no picture but still has audio
replace flyback,or,horz.output transistor
Feb 13, 2010 | Sanyo DS32920 32" TV
Sanyo DS24425 24" TV Logo
147 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
