Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio screen flashing black and white
Hi, I have a Vizio 50inch plasma TV - P50HDTV10A. The problem is when I turn it on I get a flashing screen black then white, everything else seems to work fine, sound is still there, all the buttons work, also all the inputs work, just the flashing screen. When I turn it off the power light flashes between green and yellow Ten (10) times then stays yellow. Same thing happens when I unplug it then plug it back in. The Vizio logo in the center of the TV has not lit up for a year or so and does nothing.
SOURCE: vizio p42
had the same problem had the main powerboard replaced they were out of stock and had to send mine in and vizio referbed it I was told it was a common problem with this unit
Posted on Jul 28, 2008
  • 92 Answers
SOURCE: Plasma does stay powered on
Your sustainer board is probably bad. You need to get the Y & Z sustainer boards replace then it should be okay.
Posted on Feb 09, 2009
  • 56 Answers
SOURCE: my vizio vx32l will not turn on. vizio logo will
The main board has failed. Replace the main board will fix the problem.
By the way, where did you buy the TV? If you have bought it from Costco then try to give them a call to see if it still under warranty.
Hope this will help.
Posted on Feb 19, 2009
  • 73 Answers
SOURCE: 50" Plasma Vizio P50HDTV10A - no video - just flashing B & W
Don't replace anything, Vizio has issued a lifetime warranty for this set because of this problem. No joke, call the customer service line and tell them you got the pop of death. They'll send someone out to 'repair' the set free of charge. If they can't fix it they'll give you a new one. Even if your mfg purchase warranty has expired. Call them and post the results. I've been fixing TV's longer than I care to admit and this is the first time I've actually seen a company stand behind their products like this. I bought a broken tv with the intent of fixing it and after replacing almost every board I could only manage to get the vertical racing stripe line, except mine was purple. I put it all back together and called to find out if there was a recall on this set and within 5 minutes the (Actual English speaking) gentleman told me to sit tight and he'd have a repairman come and do his thing. He did, and long story short, he couldn't fix it. Last week they delivered a new TV to replace this one. I was shocked. I think Vizio will have all my future business.
Good luck.
Posted on Mar 23, 2009
  • 92 Answers
SOURCE: No Screen or sound
there are two possibilities to this problem. First and cheapest way is to replace the main board. Second, replace the inverter board. This is the boards that are mounted vertically on both sides of the TV.
Posted on Jun 18, 2009
Vizio p50hdtv10a HDTV whole screen is black except for purple and white vertical lines in the middle of the screen
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 16, 2015 | Vizio P50HDTV10A 50 in. Plasma HDTV
50" Vizio sound but no picture
those plasma hove a lot of problems with the y-sus board signal board take you meter check cops ics. was it flashing black and white before you replaced the boards
Feb 19, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Flashing vizio plasma tv
Open it up and locate the source of the clicking. Chances are that is the defective board in your set.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2017 | Vizio P50HDTV10A 50 in. Plasma HDTV
Multiple vertical white lines
As you mentioned its sounds like the X buffer (Right and left) of your tv is faulty. There are two boards in your tv for driving the X plane of the plasma panel. Normally you can find these board on the top or bottom portion of the TV. . Its part numbers are Right buffer board is 6870QSC107A 6871QRH073A and Left buffer board i EAX35683901 EBR35855501. Before purchasing the boards identify which board is faulty. That you can find easily. Check which portion of the screen have vertical line in right or left side of the panel. The board for that side is faulty.
You can find these boards on the following link.
If you need any more assistance feel free to contact me through fixya.
Dec 12, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a 50" vizio
inverter board is not working, check dry soldering, bad capacitor or fuse
Aug 24, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a vizio hdtv and trying to hook up wii. Get it but is in black and white
Hi Friend,
Just check which TV system you have. I mean PAL/NTSC/SECAM or AUTO set it according to your country.
Good Luck.
Dec 20, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. HDTV Plasma Television The picture started flashing in and out and then the picture went black. The power light is on, has sound no picture. only 2 yrs old
I repair a tv just like yours with same problem. I replace the x and y sustains boards. If you do replace them, please make sure it is disconnected from power outlet.
Aug 26, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
22 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
