Question about Hotpoint Aquarius WF220 Front Load Washer
Balance weight hits case - Hotpoint Aquarius WF220 Front Load Washer
My washer makes loud noise when spin. Does anyone know what could cause this? Kenmore Stack Washer/Drier Model #110.88752796
There are usually cement balance weights on the bottom of the drum mechanism. One could have come loose, and/or the drum is hitting the support posts in the case.
Nov 03, 2017 | Kenmore Washing Machines
What could cause front driverside vibration
Front driver side tyre out of balance. The balance weights used to be clipped on the rim, but with alloy wheels they a stuck to the inside of the wheel with double sided tape. Could be a bent rim if you hit a kerb in ice or snow.
Jan 06, 2016 | 2004 Honda Element
Lg turbo drum
Check if the counter balance weight is still attached. Sounds like a balance problem.
Bruno
Sep 06, 2014 | LG WM Washing Machines
My buddy has a 1988 honda accord an when it hits 60mph it starts to stutter an jerk what could be the issue ?
Check if you have one of the front tires out of balance . That is the most common issue . Did you lose a weight of one of the wheel from when it was balanced when installed . Check to see if you can see a spot where a weight was once located . did you hit a curb lately or pot hole. this alone would dent the rim and you would not know t until you really check if the tires are balance of the tires . Check that and if that does not work we will move on to the next thing to check. there is no sense just say all things it could be you start at the most obvious .
Jun 11, 2014 | Cars & Trucks
Spin cycle causing load off balance
Unless there's damage to the machine it is the load. Make sure you aren't washing to small of a load. People do not realize how fast washers spin to extract. Just like they use tiny weights to balance your car tire, it only takes a little bit of weight to unbalance it.
May 02, 2013 | Fisher and Paykel Aquasmart wl80t65c
I have Brookstones silver bullet u control helicopter and have a problem. I crashed it, and when I went to fly it again it seems like the bottom blade is hit off the tail of the helicopter. Do I just...
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Dec 27, 2010 | Shuttle 9094 Emax Remote Control...
Steering wheel is vibrating and shaking
it would be one of two things.....most commonly, there is a busted belt in one of the tires. Hitting a chuck hole pretty hard will cause this, or a curb.....the other would be that one of the balance weights is gone, causing the tire to be out of balance.....
Apr 16, 2009 | Ford Taurus Cars & Trucks
Car starts shakeing or vibrating once you hit 40 mph
There may be snow and ice packed in the inside of wheels. I would remove all wheels and clean the insides Or you may choose to have a tire shop do this and balance them. May have also lost some wheel weights.
Feb 28, 2009 | 2006 Saturn ION
Hotpoint Aquarius WF220 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
