Question about Brother mfc-8950dw p/c/s/f wl prnt duplex mfc8950dw
HOW TO CLEAN THE PRINTER CARTRIDGE OF BROTHER mfc8950
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: no black. cartridge replaced with new.
Hi
Some times it needs a good clean up but this is up to you if you want to do this I put down here. But after you don this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 15, 2010
Clean brothers mfc240 print head
You need to follow these options for cleaning your printer.
1. open your case and remove the cartridge from your printer and clean your cartridge area.
2. now you need to clean paper rolloer area.
3. once you will do that then you need to clean your printer tray and other area.
How To Clean The Cartridge For Brother MFC 240C Printer
for more information please watch this video.
Feb 21, 2015 | Brother MFC Office Equipment & Supplies
Faded print
Clean the corona wire again using a q-tip moistened lightly with water or glass cleaner. Try carefully shaking the new toner cartridge back and forth to evenly distribute the toner inside the cartridge.
Wipe the scanner window (inside the machine close to where the drum rotates) clean with a soft, lint-free cloth. See page 74 of the user manual.
Power down the printer and clean all silver contacts on the toner cartridge, drum cartridge, and corresponding contacts inside the printer body.
Re-seat all components ensuring the drum cartridge is fully inserted and try printing again.
Here is a link to your user manual Page 91 for troubleshooting image problems. http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 22, 2014 | Brother MFC-J4510DW All-in-One Inkjet...
Faded left side of printed page
You can find the answer to your left side faded brother laser printer problems here => https://www.youtube.com/watch?v=WehskXO87fY
Dec 03, 2013 | Brother HL-2240 Monochrome Laser Printer
I have a Brother DCP-165C printer. It will not let me clean..it keeps saying "can not detect black " . I've replaced the black cartridge ,but it still says "cannot detect" and will...
Hi
The brother printer's cartridges do not have smart chip hence its a mechanical problem in the cartridge hence remove all the cartridges and inspect with a spot light in the cavity where you install the cartridges there may be something causing the sensor to malfunction. And at the same time try to shake the cartridge a little and then install back slowly as there is a lever which is present in the front portion of the cartridge and this what the printer looks for.
DO RATE MY SOLUTION
Jun 30, 2011 | Brother DCP 165C Compact Color Inkjet...
After installing a new ink cartridge. unit says no cartridge. tried reset procedure. tried a different cartridge. called brother went through procedure with tech service person. he was no help.
Take a wet Cotton clean the connections ..
Step 1: Remove, inspect, and reset the problem cartridge
Step 2: Clean the problem cartridge contacts
Step 3: Repeat repeating and cleaning steps
Step 4. CONTACT TO HP SUPPORT
Step : Remove, inspect, and reseat the problem cartridge and Clean the problem cartridge contacts..
a) Make sure the printer is on. Press the Power button if it is not lit.
b) Open the printer cover, then wait until the print cartridge carriage is idle and silent
c) Press down lightly on the end of the problem cartridge to release it.
d) Slide the cartridge out and inspect it:
* Check the Copper electrical contacts (the Copper Part which touch the Connector inside)
* Clean it with the pirit or wet cotton)
* Check the Nozzles - Clean it with the worm wet cotton
* Wait for 2 to 5 min befour you connect them back
* Clean the contacts in the carriage, inside the product (Printer)
* Reinstall the cartridge.
* Reconnect the product to the electrical outlet.
* Close the product cover.
Jan 04, 2010 | Brother MFC 420CN All-In-One InkJet...
Brother 6690 new yellow cartridge will not print
check the following steps
NOTE : you can also check the print cartridge label and make sure it incompatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
Note : If the cartridge is compatible, reinstall it in the printer:
* Cartridges marked with a triangle go into the left carriage slot.
* Cartridges marked with a square or pentagon go into the right carriage slot.
If issue not resolves Repeat repeating and cleaning steps
Jan 04, 2010 | Brother Office Equipment & Supplies
Brother mfc 240 c Will not recognize G&G Ink cartridge
try to clean the pinout of ur cartridge and of ur printer cartridge mount with acetone
Jun 08, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother dcp-7020 printer shows error back door open.
open the front door then pull away your ink cartridge then clean dust or blur from ink cartridge position then refix ink cartridge again.
Mar 21, 2009 | Brother DCP-7020 All-In-One Laser Printer
Printer does not see the new cartridge
try use Q-tip with water to clean up carriage the contact copper
Dec 12, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother mfc-8950dw p/c/s/f wl prnt duplex mfc8950dw Logo
55 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
