Question about Craftsman 315.10520 Polisher
Replacement part for model 315.10520
Disc part
Replace friction wheel Snapper 3317523BVE (7800254) - Snapper 33" Rear-Engine Rider
Warren, Could not find your particular model, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HowTo Replace Your Disc Drive Friction Disc Wheel
Riding Lawnmower doesn go foward Drive Disc Replacement
snapper clutch repair for beginers friction disc
Snapper Friction Drive Modification
May 13, 2016 | Snapper Garden
I WANT TO REPLACE HARD DISC, I WANT TO KNOE THE PART # OF THIS PRODUCT
Read the type, make and model from the disc you wish to replace and look on ebay for a similar model.
Mar 12, 2015 | Computers & Internet
Is there a disc that can fix a Dell 0147 optical error?
There is a slight possibility that a cleaning disc might work. They are basically a CD with mini brushes on them to clean the lens of the laser that reads the information from the disc. There is a chance that the drive's motor's or electronics on the inside have gone bad as well. I would say that the best way to tell the difference between the two situations, is to judge how much the disc drive has been used.
f you haven't used the drive in over six months, then the lens might need to be swept free of dust. On the other hand if you use the drive often for tasks like data backup, watching DVD's, or playing games that require a disc be inserted; then you probably have a disc drive that has failed and needs to be replaced. Some Dell's like the D630 that I have make replacing the disc drive really simple, but other models take more patience. Generally a replacement disc drive for a laptop is only 50-75$ at an on-line auction site like E bay.
There is a slight possibility that replacing the firmware for the disc drive could fix the problem. I would recommend Leaving any firmware upgrades to professionals, or tech. savvy friends. Firmware updates can break a drive completely. For example if the wrong drive manufacturer or model was updated, it could potentially brick your disc drive. By the way brick is a tech. term meaning to break beyoned repair rendering it completely useless.
the cheapest thing to do is get a CD cleaning kit. You might even be able to find one at the dollar store. Please don't be disappointed if this does not work. That means that the next logical step would be either replacing the internal disc drive, or buying an external disc drive.
Aug 31, 2011 | Computers & Internet
Model #GWA-4164B DVD Writer does not recognize any disc Cd or DVD. computer sees the drive when you install a DVD it tries to read and fails . Try to explore it indicates please insert a disc. Firmware is...
It sounds as if the disc drive laser has died, when they burn out they will not recognize any disc inserted. fortunatly a replacement drive is relativly inexpensive to replace.
Aug 24, 2009 | Hitachi Computers & Internet
The fan
explain better.
if the fan is damaged, replace the fan. the fan wouldnt cause disc read error. only they that would cause is the system to overheat.
replace the laser on the slim ps2. this will correct the problem. make sure u get the correct model laser. if not the laser wont match the firmware. the model can be found under the laser. google the model laser on try ebay
May 19, 2008 | Sony PlayStation 2 (PS2) Console
Bad disc or insert disc problem
If you are using a copied disc try a real one. But this model of DVD Player is made so cheap. it sound like the laser assembly is bad or the motor that spins the disc is stuck or going out. If you are good at electroninics you could take the lid off load a disc and see if it spins if not give it a spin clockwise and see if it takes off. You probably should replace unit for price of a new one.
Dec 31, 2006 | Cyberhome CH-DVD 300 DVD Player
Craftsman 315.10520 Polisher Logo
61 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
