Question about Topeak Joe Blow Sport Pump
Ball connector how to use a ball connector?
Need torque scecs for control arm
1) Install or connect the following:
  • Lower control arm
  • Control arm bolts and nuts
  • Ball stud to the knuckle
  • Ball stud castle nut, tighten the ball stud castle nut to 22 ft. lbs. (30 Nm), plus 135 degrees
Note: Do NOT loosen the ball stud nut in order to align the ball stud nut slots to the ball stud cotter pin hole. If necessary, tighten the ball stud castle nut in order to align the ball stud castle nut slot to the ball stud cotter pin hole. Ensure that the cotter pin ends do NOT contact the ABS wheel speed sensor, the ABS sensor connector or the drive axle.
  • NEW cotter pin and bend the ends
  • Stabilizer shaft link
  • ABS wheel speed sensor jumper harness to the harness retainer clips
  • ABS wheel speed sensor connector
    • Lower control arm nuts, tighten the lower control arm nuts to 71 ft. lbs. (96 Nm)
    • From Chevrolet web site.
Jan 30, 2013 | 2005 Chevrolet Uplander
Switch for roller brush not working and brush not going round, any help plz?
mikerobin143 's solution
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
http://i471.photobucket.com/albums/rr74/NinjaRider08/Dyson_DC15.jpg
Nov 01, 2010 | Dyson DC15 All Floors - The Ball Bagless...
My machine keps stopping and giving a 6E message
Hi
Thanks for using FixYa. Error 6E is a ball sensor error which is displayed due to loose Ball Sensor Connector and/or when the Ball Sensor goes bad/is out of order. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | LG Washing Machines
HPTFT5600 RKM Tracker Ball Connector colurs goto PS2 connector
Sorry to say but there is no standard on the color of the wrie used in any brand of the mouse or key board, I GOOGLE the PS2 PIN OUT and these are what I found: http://www.burtonsys.com/PS2_keyboard_and_mouse_mini-DIN-6_connector_pinouts.html
http://www.bbdsoft.com/keyboard.html
http://www.allpinouts.org/index.php/Mouse/Keyboard_(PS/2)
http://en.wikipedia.org/wiki/PS/2_connector
You need to find out about the wiring of your track ball. Brand and model? Hope this will help.
Mar 05, 2010 | HP TFT5600 RKM (Black) 15" LCD Monitor
Craftsman 32 cc
theoretically the primer ball is the t connector.
Aug 01, 2009 | Craftsman 25cc Gas Line Trimmer
How do I replace the upper ball joints in my 2002 Ford Explorer?
The upper ball joints are replaceable without replacing the control arms. Use Moog K80008 ball joints and a ball joint press.
Jun 25, 2009 | 2002 Ford Explorer
Topeak Joe Blow Sport Pump Logo
Top Topeak Cycling Experts
Michial Gueffroy
dante
jimmarmor_ma
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
