Question about Xerox WorkCentre 6505N - multifunction fax / copier / printer / scanner color
Xerox 6505: says paper jammed, but it is no paper jammed
SOURCE: paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
Posted on Oct 23, 2008
  • 17 Answers
SOURCE: repeated paper jams
These errors are usually caused by a cracked DM Camshaft (Drum Maintenance). This was a very common problem for Xerox, they usually broke while under warranty, but there a heck of a lot out there that are just now going bad after a year.
You may or may not need to replace the "Motor Process Drive Gears" as well as the DM camshaft.
You might be able to talk Xerox into doing this as a warranty repair, if you ***** real loud.
Posted on Aug 21, 2009
  • 2072 Answers
SOURCE: Xerox M15i paper gets jammed above the fuser
Yes it is supposed to be hot. Let is sit off for an hour.
Open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Posted on Oct 06, 2009
Smith-alone
  • 360 Answers
SOURCE: xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
Take care
Posted on Jul 19, 2010
Evildice
  • 217 Answers
SOURCE: FUSER GETTING OVER HEATED IN
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Posted on Aug 23, 2010
Xerox workcentre 6505 My printer dosn't print it shows ' load manual feed slot' How do you fix this problem When copying it works perfectly
change paper source. Probably on computer in printing preferences
If it works copying then it most likely is a setting in the computer . Click on print and there should be a printing preferences option comes up before you commit to sending the print to printer.
Dec 06, 2016 | Xerox Office Equipment & Supplies
Xerox 6505 Scanner Sensor Error 062-360
Check out the Xerox.com website.
Good luck..
Oct 03, 2014 | Xerox Office Equipment & Supplies
What is the problem if xerox 6505 is noisy during operation in the imaging area
This is usually from a worn gear in the transport area. Xerox service call.
Aug 06, 2014 | Xerox Office Equipment & Supplies
Scan documents on the 6505/DN using my pc or mac, what do I need from xerox
copier/scanner should do the trick and the new product will contain all the equipment.
Oct 17, 2013 | XEROX - COLOR PRINTERS 6505DN 6505/DN...
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Xerox WorkCentre 6505N - multifunction  fax / copier / printer / scanner   color Logo
42 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
