Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Model110.44722401 water in barrel
Water sound
Yes, it is normal. The top ring was filled with water to act as a counter weight when it is going to stop from fast spinning.
Oct 18, 2013 | Whirlpool WTW6400SW Cabrio Washer
WE HAVE A FLOATING DOCK WITH BARRELS UNDER IT AND ONE BARREL HAS A HOLE IN IT AND NOW THE DOCK IS SINKING ON ONE CORNER. HOW CAN WE FIX IT WITHOUT TAKING THE DOCK OUT OF THE WATER.
I would get another barrel and fill it with water, that will allow it to sink, and be more maneuverable under water. Then you can switch it for the barrel with the hole in it, and then drain the water from the good one with a hose. Good luck fixing your dock!
Jason.
http://www.falveycorpmccall.com/marine.htm
Apr 11, 2013 | Cars & Trucks
When the dial is set for a medium load, the water fills to about the mid point up the side of the wsher barrel and stops. Then the inner barrel starts to spin at a moderate speed and the water is thrown...
Sounds to me like the pump is not operating up to par. Open the machine and check all the drain lines form the tub to the pump, from the pump to the waste pipe and also, when you check the tub to pump line, feel up into the tub to make sure you don't have a article of clothing stuck in there. Check the inside of the pump too. Here is a link to a video to show you how to access the pump and lines.
Dec 28, 2010 | Maytag PAV2300 Top Load Washer
I have mixer taps on my bath, cold water tap works
Remove the tap outer cover. Take out the barrel & inside there is the washer on the end of a screw which slides in and out when the tap is turned. This could have been turned too far out and will not go back in. Clean both the screw thread and inside the barrel, lubricate with petroleum jelly or similar and reassemble & test before replacing the barrel. Again lubricate all threads.
Alternatively buy a new barrel
Mar 11, 2010 | Home
Kenmore 111 stuck mid cycle with water in barrel
Try unplugging it for a hour - see if it clears..
Hope this helps !!
Jul 13, 2009 | Washing Machines
Standing water in the barrel
Unfortunatly this is normal for the neptune washers and there is no solution other than to use the machine often so the water does not stagnate.
Feb 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water left in barrel (not the tumbler)
If you can't see any water and just hear it, this is completely normal. This is a front load washer and has a special cover of the inner tub basket. This cover contains some water that has been sealed in at the factory to keep the load balanced while it is spinning.
Nov 25, 2006 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
