Question about iPhone Apps
1st grade sum dog - iPhone Apps
Column 75" tall, 16" wide and 16" deep. How many sq feet of stone to cover the column and top?
you have a rectangle of of 75 X by16 and you have 4 of those rectangles so multiply 75 X 16 and then multiply the sum by 4
then you have the ends which are squares of 16 X 16 so multiply 16 X 16 Nd then multiply the sum by 2
then add the 2 sums together to get the total square inches of the surface of the object
now one square inch =.00694 square feet so multiply the total sum by .00694 to get the area in square feet
grade 4 maths really
Jan 04, 2017 | Office Equipment & Supplies
HOW DO I CALCULATE THE MEAN IN GRADE 11?
a how to video on how to calculate the mean.
Sep 23, 2014 | Miscellaneous
I have a 2001 turbo diesel 4wd rodeo. It has started throwing out of 1st gear on take off. Doesn't do it every time but is getting a bit annoying. I've replaced the transmission oil and engine mounts (I...
old post, , M/t box. (built many)
jumps out of 1st gear.
bad shift linkage.? ever try shift it with no shift lever. to prove that? (ask)
bad 1'st gear dogs. !
bad bearing near 1st gear, causing it to bounce and jump out.
bad synchro, blocker, hub that dogs to 1st.
shift rail dentent balls failing , springs on balls, or plug fell out.
the blocker and dogs, hold the gear,
the box is constant mesh box, so gears never shift.
on the dogs lock up . (and effects a shift)
if you need a photo of that action or video that too is easy.
1st gear has the gross effect of putting huge gear spreading actions
from top 1st gear to bottom cluster, they want to spread.
so any bearings that can allow that, there, will cause 1st to fail.
easy.
Sep 10, 2014 | 2001 Isuzu Rodeo
I need to know what is a plural noun
A plural noun is more than one noun.
A "man" is a noun. The "man" plural noun is "men".
A "dog" is a noun. The "dog" plural noun is "dogs".
Nov 08, 2013 | Didax Lift Off Singular and Plural Noun...
How do I log in to Sum Dog?
Hi Jason, Click on this Link to sign in to your Sum Dog account.
If you have forgotten your password click Here to reset your password.
Hope it Helps
Dec 04, 2012 | Computers & Internet
Create a program that will input 10 grades (75:passing, 79-84:C, 85-89:B, 90-94:A, 95:A+). It will display the average grade.
This can be done in various of ways ,
a quick C implementation of this could be -
#define NUM_OF_GRADES 10
This function will average 10 grades and display their average .
short AverageGrade()
short sumOfGrades = 0; //Saves the sum of the grades .
short i = 0; //Iterator
for (i=0;i<NUM_OF_GRADES;i++)
printf("Please enter a grade:\t");
sumOfGrades += scanf("%hd",&sumOfGrades);
}//for
return sumOfGrades;
}//AverageGrade
You can either implement the printing of the average inside the function or from the calling function .
Hope this somehow helps ,
Have a great day !
-Danny
Oct 14, 2012 | Program Arts Software C-Free
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
Lost data on Dog Island
no i dont she might have to start over sorry
Mar 07, 2009 | Ubi Soft The Dog Island for Nintendo Wii
Read n & m, display the sum of all the even and odd numbers between n to m.
#include <stdio.h>
int main()
int n1, n2, i;
int sum = 0;
n1 = 3;
n2 = 11;
for (i = n1; i <= n2; i++) {
if (i % 2 == 0) {
printf("Adding %d\n", i);
sum = sum + i;
printf("sum = %d\n", sum);
return 0;
Feb 21, 2008 | Computers & Internet
iPhone Apps Logo
78 people viewed this question
Top Apps Experts
ray gallant
Are you an App Expert? Answer questions, earn points and help others
