Question about Stihl Chain Saws, 017, 019, 021, 023 & 025
Dont start when i crank she dont start
    Sergeant:
  • 137 Answers
I've noticed some problems with my old Stihl saw not starting and the solution was simply to empty out all the fuel and leave the cap off for a few days. What happens when you leave the fuel in for too long it starts to soak into the fuel pickup line ( looks like a piece of rubber hose with a filter on the end of it) and the rubber gets so soft, it just collapses just from the litlle bit suction coming from the carburetor..
When I let my air dry out for a while it became a lot more solid and my Stihl worked faithfully again.
Try the simple things first. Use new gas with right ratio of gas:oil ( too much oil makes an engine hard to start). Check that the spark plug is clear and not burnt with to much carbon. Also pull off the boot of the plug and ground it to the engine with ground it to the engine frame and see if you get a bright spark when you pull the handle
Posted on Jan 27, 2015
    Problem Solver:
  • 12 Answers
Check the spark plug is there fuel getting to the carby might have to adjust idle screw
Posted on Jan 26, 2015
Was running shut off few days later it wouldn't start
Check battery condition and connections (dirt, corrosion, tightness, acid level) to start with.
Apr 23, 2015 | 1995 Jeep Grand Cherokee
My 2005 jeep grand cherokee won't start all i getting is a clicking noise
this is a NO CRANK issues, cars dont (A/T) dont start unless they crank.
try jumper start, off another car, (good cranking NOW means battery weak)
cable jump.
work now?
charge your cars battery>?
wiggle the shifter while cranking, does it starter wake up? bingo.
or shift to Neutral, (trick2) Does it crank now? BINGO 2.
Mar 07, 2014 | Jeep Cars & Trucks
05 deville no start turn key on dose nothing
hello Allen. Deville leaks in to my Toyota, forum section, oddly?
but
Engine size not stated.
nor if it cranks robustly
if key is dead, and dash dead, and or head lights dead
check all fuses first in the cab and in the engine bay.
always check fuses first. the battery voltage.
bam 10v bad battery ,dead, or discharged, (i charge it and ./...???)_
battery is good and jumper starts fail.
you turn the key to on, the check engine light glows, (and othere)
that is something
then you move key to crank position (start) i will wiggle the shiftlever.
boom is cranks
no it dont so i try starting in neutral. bam , it cranks. over. bad PRNDL switch.
no it dont, so i hit the starter with a hammer, not crazy just tap tap.
no it dont start.
I hot wire the starter solenoid. it cranks (wont start , key in pockets)
hot wire fails,battery good, starter is toast.
hot wire test passes ,cranks nice.
i then grab my trusty DMM and flip dial to Volts.
i then find why my KEY line is dead.
if you get this far, ask how to fix a dead Key line.,
the starter ST key line,
Dec 12, 2013 | Vehicle Parts & Accessories
Refuse to start, who much will it cost me to buy another one?
another what?
NO CRANK or NO START
no car starts unless cranked fast. or pushstarted (stick) or jumper cable cranked.)
if it dont crank
1: check all fuses.
2: try jumper cable start, does it crank now (stater makes noise and engine crank shaft spins(eyes see that)
Aug 05, 2013 | Honda CR-V Cars & Trucks
Codes 12-01
dont crank at the normal 250rpm or more, yes/no
cranks perfectly but does not start ?
same, but starts and stalls in 2 seconds.?
which?
Jul 12, 2013 | 2000 Honda Accord
Suzuki wont start got power head lights turn key and nothing
I had this happen last month. It was my starter. My previous cars would miss and catch, letting me know the starter was finished, but this one just totally died, I had power for lights and gages moved, but would not start.
Mar 27, 2013 | Suzuki X-90 Cars & Trucks
No voltage on crank sensor grand am 2001 2.4
The crank and cam sensors produce ac voltage that is sent to the computer. There are magnets or components on the crank and cam that the sensors "read".
The problem could be the harness between the sensors and the computer, or a mechanical problem like a timing chain or gear.
Sep 21, 2012 | 2001 Pontiac Grand Am SE
Starter wont crank on a 2000 oldsmobile intrigue
Check your manual if you have it. I believe you need to have the key in the ignition in the ON position for about 10 minutes to reset the security system.
Jul 08, 2010 | 2000 Oldsmobile Intrigue
Starter wont crank with ignition key
Well, if you have a problem with the security system not allowing you to crank, then you have a problem that can be fixed only by the dealer.
Check your key and verify that it doesn't have a dirty or wet resistor on the security ignition key. This is a common problem with this type of security system.
Good luck on fixing this problem.
Jul 08, 2010 | 1994 Cadillac Eldorado
Crank but dont start
Fords are pieces of **** dont never buy one again. ******* **** **** ****
Jan 31, 2010 | 2001 Ford F350 Super Duty SuperCab
Stihl Chain Saws, 017, 019, 021, 023 & 025 Logo
98 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
