Question about RTO Gas Motor Scooter 50cc
50cc scooter starts but will not keep running
Starts but keep running
3 Suggested Answers
SOURCE: my 2005 50cc kymco cobra racer scooter does not start
i have fire and new cdi ran find for 2 days but hard to start now it will not start
Posted on Mar 26, 2011
MOTORWIZJ
  • 1383 Answers
SOURCE: got a kinroad 50cc scooter wont start got fuel got spark can anyone help?
SEE IF IT WILL START ON A FEW DROPS OF GAS, IF SO YOU NEED TO CHECK FUEL DELIVERY ,DRAIN OR CLEAN THE CARB MAY HAVE WATER IN IT OR IT MAY BE THE SOLENOID ON THE CARB THAT SHUTS THE FUEL OFF IT SHOULD CLICK WHEN YOU TURN THE KEY ON... JAY FL
Posted on Feb 03, 2012
Scooter will start inentionally but will not continue to run?
Try replacing the spark plug,, careful not to cross thread the plug when you replace it,,,
Cheers
Aug 22, 2014 | RTO 50cc Moped Scooter
What is the main cause of un passing electric to start
Hi, Bijualexander and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
50CC Scooter Wont start
How To Fix Scooter Starting Issues Part 1 Quick Guide
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
50cc scooter wont start need help
Scooter won start
Apr 26, 2014 | Bajaj Motorcycles
Scooter cuts out
check the carb float level ,and condition of needle and seat
May 18, 2013 | 1976 Honda CB 100
Chinese 50cc scooter won't run
any other previous problem prior to this?
Aug 13, 2012 | 2005 Qianjiang QJ150
My 2005 50cc kymco cobra racer scooter does not start
Jun 27, 2010 | RTO 50cc Moped Scooter
Peugeot Vivacity 50cc Kickstart broken, but engine fine
the kick stater machanism has a spring on it
which may be brocken
Cheers Rob
Sep 17, 2009 | 2001 Honda Cityfly
50cc Two Stroke Scooter Engine - Poor Idle
I had the same problem- from out of nowhere the scooter started dying at every stop. I adjusted the idle screw to 2000 and it still idled up and down. I bought some injector cleaner but this will take a while to work (several tanks of gas) and then found this link- seems to be a very simple thing to do once you read this link. I hope it helps. --
Mar 14, 2009 | Toys
RTO Gas Motor Scooter 50cc Logo
18 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
