Question about Minolta bizhub 200 All-In-One Printer
Konica minolta error code-1183 - Minolta bizhub 200 All-In-One Printer
  • Minolta Master
  • 6,680 Answers
Did some one hit the output trays on the finisher or did some one leave a trash can or boxes under the finisher trays. This code means that the elevation motor assy. for the output trays need to be re-adjusted. Have to remove the rear cover of the finisher remove the motor assy. Be care that the trays don't go crashing to the bottom. Recommend a technician do this.
Posted on Dec 29, 2014
5 Suggested Answers
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
firecontrol7
  • 6680 Answers
SOURCE: Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Posted on Jul 19, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: how to fix error c-1183
This code is for a bin/tray raising or lowering failure in the finisher. This can be caused by either the trays not being fully inserted into the finisher or something stropped the bins from raising or lowering. Check the trays and make sure they are as close to the finisher/fully installed as possible. Then turn off then back on the main power switch (NOT the stand by one on the control panel)
You should see the bins raising and lowering into their home position.
Posted on Aug 03, 2010
SOURCE: Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
http://ewpm.eu/konika-minolta-2300-w-fehlercode-0eh-17h
Posted on Jun 02, 2013
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Error code c-1133
maybe you mean C-1183? could not find 1133 in the service manual
Aug 07, 2014 | Konica Minolta Bizhub C300 All-In-One...
Konica minolta c-1183
The output trays hit something was a trash can or boxes stored under the trays? Have to reset the Elevation motor physical. Technician required unless you want to open the rear of the finisher and remove the elevation motor assy. Ensuring THE TRAYS DONT DROP DOWN.
Jun 20, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Error Code C-11831
You mean C-1183? What mode machine and finisher type?
Feb 21, 2014 | Minolta Office Equipment & Supplies
Internal error c 1183 code on konica minolta 283
Sir/mam
Did someone leave a trash can or boxes under the output trays? To solve this problem requires removal of the rear cover of the finisher. Then remove the elevation drive motor assemble. Be careful don't want the output trays to fall!!!!!! Then while placing them in their proper position re seat the drive assy. The top tray should be just below the orange rollers (If they are cleaned) you will see several actuators the top tray has to just touch them.
Jan 07, 2014 | Konica Minolta Office Equipment & Supplies
Trouble Code C-1183
Your machine output trays hit something like a trash can or boxes store under the machine. Have to gain access to rear section of the finisher to reseat tray elevator drive assy.
Jan 18, 2012 | Konica Minolta KONICA BR BIZHUB C451...
How to fix error c-1183 konica-minolta bizhub 200
Aug 03, 2010 | Minolta Office Equipment & Supplies
C1183 error
C-1183 = Elevator Motor Ascent/Descent Drive Failure
This code means something is stopping the finisher exit trays from moving. Check your finisher exit trays. Make sure nothing is under them blocking the movement. Make sure they are level and have not been knocked out of place. Open and close the front door and reset the machine power and see if the trays move. They are suppose to move and find home position when resetting.
May 24, 2010 | Konica Minolta Bizhub 362 Copier
Konica Minolta Bizhub c-353 has an error code c-1183 which will not clear for me It's Saturday and I have a HUGE project with lots of people coming to help.
The finisher output trays hit something like a trash can or boxes stored under the trays. to fix must remove the rear of the finisher reset the elevation drive assy. Be careful don't let the trays fall down tech would be good on this project
Nov 01, 2008 | Minolta Office Equipment & Supplies
Minolta bizhub 200 All-In-One Printer Logo
54 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
