Question about Canon imageCLASS MF8180C All-In-One Laser Printer
JUNK I can't even do anything because of this error.... It won't let go into anything except the menu and that's not helpful at this point.
  • 76 Answers
Both these errors are fuser unit (fixing unit) i would take the unit out and reinstall it, if not order a new fuser unit.
hope this helps
Posted on Oct 24, 2008
0 characters
3 Points
Canon multipass pixma mp500 waste ink absorber full
printers are cheap buy a new one or look in a dumpster where university students live and have been throwing out junk cuz they are done with school.
Nov 23, 2013 | Canon MultiPASS MP730 All-In-One InkJet...
System error T01-521
Error type T01 [Main-motor lock]
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset
Error point Error conditions
The main motor limit sensor does not go ON/OFF for more than 16 pulses while
the main motor is operating, even after the elapse of 100 ms.
The position-A sensor does not go ON/OFF, between two detections of position-B,
while the main motor is operating.
The position-B sensor does not go ON/OFF while the motor is operating, even
when 3033 pulses are received at the Main FG.
The clamp unit is not at the home position while the print drum is operating
(Clamp sensor C: OFF, except during master disposal).
536 The drum failed to stop at position A. (over-run)
537 The drum failed to stop at position B. (over-run)
The print
Sep 24, 2013 | Riso RP 3700
Hp 2840 won't stop printing
power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
Feb 21, 2013 | HP LaserJet 2840 All-In-One Printer
Alps MD1000 printer won't do anything.
Do you get the green ready light when you first turn on the printer?
Nov 05, 2012 | Alps MD 1000 Thermal Printer
The printer doesn't save anything in memory except faxes that come in while paper or toner is empty. Once the error is corrected they will print. Otherwise you step thru the fax menu and see if there are faxes in memory.
Jan 07, 2010 | Samsung SCX 4521F All-In-One Laser Printer
If you subscribe to a caller ID service through your phone provider, you can block
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
number in the blocked fax numbers list, the fax is not printed.
Set the junk fax mode
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
service through your phone provider, or do not want to use this feature, you can turn
off this setting.
To set the junk fax mode
▲ Some models have a Block Junk Fax button. Depending on the model you have,
do one of the following:
Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
Feb 11, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Printer problems
Sorry for your frustrations. Throw the piece of junk away and save yourself from recurring aggrevations.
Jul 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Copy problems
try to adjust color saturation :
Press Menu/Set, 3, 4.
2 Press ▲ or ▼ to select Red, Green or Blue.
Press Menu/Set.
3 Press ▲ to increase the colour saturation.
Press ▼ to decrease the colour saturation.
Press Menu/Set.
4 Return to Step 2 to select the next colour.
Press Stop/Exit.
Jun 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
Pls open cover
This could be caused by a series of things the best way is to check the error code. While powering up hold down MENU/SET
then you might see MAINTENANCE or you might get a machine error. enter 82 if you see maintenance. It should say Machine Error 00. Meaning no problem. Any other number will let a service tech know what the problem is. Press STOP then enter 99. It might reset at that point.
Jan 07, 2008 | Brother MFC 6800 All-In-One Laser Printer
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
49 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
