Question about Whirlpool Cooktops
Whirlpool error c8 - Whirlpool Cooktops
What does the code"F5E2" mean when trying to use the self-cleaning function?
This error means that the door lock didn't engage properly. This could be a wiring problem or a problem with the switch. First disconnect the range from power and check the wiring and switches from the control to the switch and back. If the door was locked when the F5E2 error was observed, then replace the door switch.
If the door was not locked, then check the door switch and the latch switch. Replace the bad switch.
The rear door switch is part W10107830, https://www.partstore.com/Part/Maytag/Maytag/MER7765WW/Whirlpool/Whirlpool/W10107830/New.aspx . A useful parts diagram is here: http://www.searspartsdirect.com/model-part/mer7775ww0/3048/0124111/W0908230/00003.html .
After replacing the bad part, reconnect the power to the range. Press and hold any key for a minute to clear the F5 code from the memory. Then press Cancel to clear the next code you see. Check if the range works.
I hope this helps.
Dec 23, 2015 | Maytag MER7765WW Freestanding Smoothtop...
Whirlpool error code e2 f3
The error codes are in the operating instructions if you don't have it ask Bosch to email the error code page to you.
Apr 10, 2014 | Bosch Cooktops
Error code f6e4lost communication to Whirlpool Range
Do you have the manual? It should tell you in the trouble shooting part. There's a website whirlpool.justanswer.com another website is brunswick-ga-appliance-repairs.com this will list the problem you may have, try turning off at the mains and back on again. Hope this helps
Mar 22, 2013 | Cooktops
Whirlpool oven code E2F3, and oven never gets up to the correct temp.
The thermostat in the oven itself needs replacing. Unfortunately, you'll probably need to get a professional in to do this job.
Oct 21, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
Eo f2 code shows it constantly beeps and was wondering how to fix
Hi
Thanks for using FixYa. Error F2-E0 in your Whirlpool range indicates shorted keypad. To resolve this issue you’ll have to replace the electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Whirlpool 30 in. RC8700 Electric Cooktop
WHIRLPOOL AKR 301 IS FLASHING O3 F Fault code
Jan 09, 2010 | Cooktops
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 | Cooktops
Cooktops Logo
76 people viewed this question
Top Whirlpool Cooktops Experts
Timllfixit
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
