Question about Solstice Quest 285 Sport Boat
Deflating floor will not deflate completely
How do I deflate spa
To deflate the portable Therapure spa 050006 is easy. The trick is to realize that the black valve used to inflate is in fact a double valve. Remove the square threaded cap to inflate it.
1. To deflate the spa leave the black square threaded cap and below that you should find a round or winged coupler.
2. Unscrew this coupler off and immediately the air will start to escape. It shouldn't take more than about 2 minutes to deflate and you are ready to pack it away.
3. Return the valve (before doing so you could use a vacuum to suck out as much air as possible.)
4. Lay out the spa floor in a circle
5. Fold the three sides to the centre
6. Then lay the power unit on the folded sides.
7. Remove the coupler one more time to squeeze out any remaining air and then return it.
8. Roll the up the side to the original size of the spa before you opened it the first time.
Sep 18, 2014 | TheraPureSpa New 2 - 4 Person TheraPure...
How do you deflate a portable spa
Nov 23, 2013 | Therapure Pool & Spa
How do I deflate the spa?
the fastest way to deflate any inflated spa is 1st drain water away , then using a shop vac suck the air from the chambers , it takes but a few minutes to complete that way
take that from guy that's allways in a hurry !!
Sep 20, 2013 | Therapure Four Person Inflatable Round Hot...
WANT SOLUTION ON BLOW UP RIM, PLEASE, NOT FILTER
If this is deflating you should take some soapy water and go around the complete to rim beginning at the seam and locate your Leak.
Rod
US Parts Center
888-521-6183
Mar 04, 2013 | Intex Pool & Spa
Can I inflate/deflate an exercise ball?
Ofcourse youcan! Check out these two informative websites to learn how to inflate/deflatean exercise ball: www.livestrong.com/article/22214-inflate-exercise-balls/and http://www.livestrong.com/article/73718-deflate-exercise-ball/
Aug 06, 2012 | Exercise & Fitness
How do I inflate/deflate my water trampoline?
You can inflate your water trampoline with either an electric pump or a manual pump. I suggest using an electric pump because it will save you a lot of time and effort. In terms of deflating, you also have 2 options. You can simply open the air valve and allow the tube to self-deflate or use a two-way air pump to remove the air.
Jul 31, 2012 | Sport & Outdoor - Others
How do you deflate the northwest territory queen size air bed
I was confused by this too. Here's the trick:
When you inflate the mattress, you unscrew the square-shaped plastic cap, like this:
But this is *not* the cap you unscrew to deflate it!
To deflate it, you have to unscrew the plastic at the *round* part that's beneath the square cape -- i.e. the part of the plastic that's affixed directly to the mattress. When you unscrew the round part, the entire plastic apparatus detaches from the mattress, leaving a big open round hole where the air rushes out.
It looks like this:
Jan 06, 2012 | Baby Gear
My rear air bags are too high and will not deflate. The sensor is connectod ok on the rear arm. How can I deflate it manually. It is on a 1994 mark VIII
you can remove the rear lines at the air bags to deflate. most likely the problem is the air suspension control module is not turning the venting valve on to release the air from the bags.
Aug 10, 2011 | Lincoln Mark VIII Cars & Trucks
Dacor/Mares Airtrim
Which deflate?? Could just be it needs a service.. Has it had one recently??
Jul 16, 2009 | mares JUBILEE Buoyancy Compensator
My airride on 2000 lincoln navigator will inflate but not deflate
MY 2000 LINCOLN CONT INFLATED A MONTH AGO AND WILL NOT DEFLATE. THE LIGHT COMES ON SAYING CHECK AIR RIDE SYSTEMS. HOW DO I DEFLATE?
Apr 11, 2009 | 1999 Lincoln Navigator
Solstice Quest 285 Sport Boat Logo
65 people viewed this question
Top Solstice Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Solstice Boating Expert? Answer questions, earn points and help others
