Question about Car Audio & Video
I have the high level input plug for a visonik 300 watt amp but they r cut what do I wire to them that would substitute
2 Suggested Answers
zzedly
  • 300 Answers
SOURCE: sony xplod amp xm-1652z high level input connection
First off, if you're using RCA preamp connections from the head unit to the amp, you don't need to put anything into the high level input connector. But if your head unit doesn't have RCA preamp outputs, then connect the front left to the white (+) and white/black stripped (-) wires and the front right to the grey (+) and grey/black stripped (-) wires. There is no need to connect the rear speaker outputs of the head unit to the high level input of the amp.
Posted on Apr 18, 2008
Their are 2 power wires,2 negative wires and 2 rem wires...how is this wired..im getting ready to get this put i
Some amps come with extra, power,rem,ground, so you can , power up another Amp Without runing to many wires. , or using a power block.like a parallel, being your 1st Amp your power block, and your remote, ground .
Apr 03, 2016 | Jensen JXA8BA2 Amplified Subwoofer, Max...
I DONT HAVE PLUG FOR HIGH INPUT ON AMP CUD YOU SHOW ME A PICTURE OF PLUG OR TELL ME WHAT COLORS GO WHERE SO I KNOW WHAT EACH PRONG IS
im sry about that but i got one right here an visoniks arent that bad of a amp but for ur high input u will have one next to one another left to right is + - then under that is the same u can only hook up four speacker to the one i got . i hope this helps if so please votes
Jul 19, 2011 | Visonik VB-10PKG Car Audio Amplifier
What wires do I hook up to the high level in plug that came with my dual xp2100 2 channel amp
First, know that you need either high level input or low level input, but not both. Low level input is preferred (RCA cables). If you must use high level input because your head unit doesn't have RCA jacks, you connect the speaker outputs from the head unit to the high level input of your amp. The high level input plug probably has a black wire, this is "signal reference ground". A pair of grey wires which are right positive (grey) and right negative (grey with black stripe). And a pair of white wires, left positive (white) and left negative (white with black stripe).
Feb 26, 2011 | Dual Car Audio & Video
I have a visonik 800watt amp and i got it from a friend for free and i hooked it up right and as soon as i turned it on the 2 fuses blew then i replaced them and tryed it again and it stoped again so i...
Its the amp, do not put any more fuses in it
you need to get it checked out by a technician.
Its probably a power supply fault or blown output devices.
Hope this helps
Thanks for using FixYa
Aug 02, 2010 | Visonik V2508 2-Channel Amplifier
How do I hook up my 10 inch visonik sub woofers? they have 2 connections?
this is a dual voice coil sub. either have a 2 channel amp hook up to it. or have your mono amp have to sets of wires going out of it to your 2 connections. i dont suggest it but i have had one connection hooked up at a time played it when it blew hooked up the other connection as a back up. just make sure you have the right watt level for each voice coil.
Apr 14, 2010 | Visonik V10DV6W Car Subwoofer
Need to know what connections for 6 pin input port
honestly anything made by visonik is **** and i wouldent try wiring it like that it could have bad consequences do rca or call visonik and order a replacement
Apr 26, 2009 | Visonik V117SX Car Audio Amplifier
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Installing visonik bass system
Here is a link to visonik to download manuals.
http://old.visonik.de/en/downloads.php
If you let me know your model number of the sub, vehicle make and model, and brand and model of headunit or CD player you have then i can provide wiring color codes, recommended wire routing locations, etc...
Jan 03, 2008 | Visonik 10" 500-Watt Single Bandpass...
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
