Question about Victor 1260-2 Calculator
How do I change the time from am to pm?
Everything else has changed correctly, but I can not remember how to change the time from am to pm
Caldera spa, night mode coming on in middle of day how do we change this please
Make sure the AM/PM is correct when you set the time of day. If you can't select it, then use 1300 as one PM and go from there 2000 is 8 PM
Jul 28, 2017 | Pool & Spa
Why does the date on my seiko sne881 change at 12 noon?
probably because you have it set to 12 pm midnight and not 12 noon so at 12 noon it is actually midnight when the date will change
reset the time of the day to am or pm and any pm settings will change the date at 12 midnight.
Aug 30, 2015 | Seiko Watches
On firefox can't open my email it says untrusted
Pls.check your system date & time is correct ???
Pls Try to correct your systems Date & time on the extreme right corner of your screen.
after change date & time it corrected.
if Problem comes again with Date & Time you need to replace BIOS / Motherboard Battery.
How to change date & time
Option 1>>>
Open the command prompt:
  • Click Start.
  • Type "command prompt."
  • In the results, click on Command Prompt
  • Type the word "time". Type a space, and enter the new time in the following format:
    • HH:MM:SS AM/PM. For example, time 5:34:00 PM, time 12:15:00 AM, etc.
    • Press enter or return.
Type the word "date". Type a space, then enter the new date in the following format:
  • MM/DD/YYYY. For example, date 5/15/2009, date 2/14/1999, etc.
Option 2>>>
  1. 1Open the command prompt:
    • Click the Start button.
    • Click on All Programs.
    • Click Accessories.
    • Click Command Prompt.
  2. 2Type the word "time". Type a space, and enter the new time in the following format:
  3. 3Type the word "date". Type a space, then enter the new date in the following format:
  4. 4Check the clock in the bottom-right hand corner. The time should be successfully change.
Sep 02, 2014 | Google Computers & Internet
How do i change the time on my hisense tv
Hit Menu on remote -
scroll down to SETUP - hit Enter, the text changes color or brightens, Scroll down to Time Setup - press right arrow,
select Time - turn Auto Synchronization OFF - then you should be able to change time, as this will be highlighted, you can actually change the number (time) in that area,
Remember to make sure you leave the am or pm as neeed. If you press Enter after changing time it changes the am to pm, so leave as correct and exit out. Have a blessed one.
Oct 06, 2012 | Hisense Televison & Video
I dont remember my psn password and to change it i need the birth of date witch i also forgot :(
There is no way to recover the account if there is an issue with birthday.
-however you may call Sony support department.
Consumer Services Department
800-345-SONY(7669)
Hours of Operation
Monday - Saturday 6:00 AM - 8:00 PM Pacific Time
Sunday 7:00 AM - 6:30 PM Pacific Time
Mar 05, 2011 | Video Game Consoles & Games
I cannot get my ihome ip11 model out of military time. Help. Thanks for any help you can give
Hello pac31:
For 12 hour time format setting: Press the Alarm Ser Button durin time setting to set 12-hour 24-hour display format. Remember to set the correct AM or PM time (an icon to the right of the time display is the PM indicator ther is no AM indicator).
Remember to click the thumbs up if this helps.
Sincerely, Peter
Mar 02, 2011 | Audio Players & Recorders
Just bought a Lacoste watch,and I am puzzled why they stress the importance of not changing the date between the hours of 11.45pm and 2.00am?.
If you change the date between those hours, and the watch is set for the correct time, it may automatically roll the date forward yet again. It could mess up the internal mechanism for changing the date. The date starts to change around 11:45 PM and can take a good long while for it to fully "engage" the new date, which is why they say to wait til 2:00 AM. The internal mechanics that change the date are very sensitive. If you force it to change the date while it is automatically trying to change it, it can off-set the little gears and they may not function correctly in the future. So just make sure the time on the watch is not between 11:45 PM and 2:00 AM when you change it. The best thing to do is to change the date to the day PRIOR to the day you want (for example today is the 21st, set it to the 20th, then advance the hour / minute hands past midnight so it automatically rolls into the 21st, and then you will know if you are on AM or PM).....
But just avoid setting it between 11:45 PM and 2:00 AM as they mention.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 21, 2010 | Watches
I need to reset my tomtom clock from A.M. to P.M. It's a 340-S
i have a tomtom one, not sure if they are all basically the same, but try this. you should be able to via the settings menu. tap screen, tap 'change preferences' and scroll through the screens until you see 'change time' use the little arrows to set the correct time, and then select 24hr mode. if you are not happy with 24hr mode then select 12hr mode. if you know it is pm but sat nav is showing the correct time but in am, then simply increase the hours by 12.
Aug 05, 2009 | GPS
Forgot how to change time
Press and hold the Clock button (far left button in group of three) until the time begins flashing on the display. Press and hold the Forward(>>) or Reverse(<<) button to set the time. Remember to watch for AM or PM. The PM indicator is in the lower right side of the display. When finished you can either press the Clock button to set the time or after about 7 seconds it will automatically set for you. A"Beep" sound confirms that the time is set.
Oct 08, 2008 | Timex T276B Clock Radio
Change am to pm.
  • Tap the screen to bring up the menu
  • Tap the 'Change preferences' icon
  • Tap the arrow right to the icon 'Set clock'
  • Choose how to display the time (18:00 , 6:00pm , 6:00)
  • Set the time (You can also tap 'Sync' to synchronise time with your PC)
Jun 13, 2008 | Tomtom One XL GPS Receiver
Victor 1260-2 Calculator Logo
27 people viewed this question
Top Victor Office Equipment & Supplies Experts
Greg Cann
Greg Cann
D. E. Hev
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
