Question about Jandy Laars Lite2 Ld 400,000 Btu Heater
Fl4 and fl3 fault
Fl4 and fl3 faul how do I fix this?
    Champion:
  • 246 Answers
Fl3 not rectification fl4 fault ignitions must replace ignitor kit and rectification kit from jandy need model # for parts
Posted on Sep 14, 2009
How do I test A ECM.
You would have to have a diagnostic computer terminal to plug into the OBD connector. This device can run a series of tests to see whether any trouble code or other fault can be detected.
http://cdn.instructables.com/FL3/AZVZ/HLSGZXQL/FL3AZVZHLSGZXQL.MEDIUM.jpg
Nov 21, 2015 | Cars & Trucks
How i can remove the fault code b1589 vizt 2007
to effectively remove the fault code there has to be a repair of the item that the code refers to. just putting the light out fixes nothing
Dec 24, 2014 | 2009 Toyota Yaris
Reset code 4
According to pages 34-38 of the installation and operations manual, FL4 is one of the codes that does not automatically reset itself after the fault is repaired. To reset the controller after an FL4 (or 6 or 7), press the "Select" button until the heater is off, wait a minute or two, and then press "Select" to put the heater into "Pool" or "Spa" mode. The heater should then go through the ignition sequence and function normally. NOTE: The manual also says that an FL4 code should be fixed by a professional.
http://www.zodiacpoolsystems.com/~/media/Zodiac/Global/Downloads/H/H0248900.ashx
Jun 20, 2014 | Jandy Lite2 LJ 400P, 400,000 BTU Heater,...
Fl 4 code
fl4 = Igniter Failure
A. Igniter circuit is open: Check fuses on igniter wires
B. Element has a fine crack in it: Replace igniter
C. Igniter fault: Replace igniter
Apr 09, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
We have a CTM HS-2800 power wheelchair that has 2 red, 2 green & 2 yellow lights that come on flash 8 times and then go off. What might be the problem when this happens?
You have a module problem:
Evaluate your batteries. 12v Single or 24 together.
Flash codes:
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul
8. Power Module Faul
9.Shark Module Faul
Nov 24, 2010 | Ctm HS-2800 Power Wheelchair
Ctm hs 2800 turn on key light come on and blink 7 time then go out push joystick foward motors kicks in and out and lights blink 7 times and then frist red light keeps flashing
3. Left motor Fault
7. Shark Control Module Faul****this will be your problem***
9.Shark Module Faul
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
Oct 31, 2010 | Ctm HS-2800 Power Wheelchair
Fl4 problem, kenmore elite won't spin or drain anymore.
EEPROM Error
The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU.
If there is an error reading this data, it will cuse this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
The joystick will display a sequence of flash codes. Count them and find the count here: This could be several issues, But the flash code will tell you for sure.
3. Left motor Fault
9.Shark Module Faul
Mar 07, 2010 | Ctm HS-2800 Power Wheelchair
How do I fix a FL4 code
A FL-4 error is an ignitor failure. There are three things that need to be checked to correct the issue. First is the ignitor. Replace if broken or burnt or cracked. Second is the 220/120 vac conversion plug that is plugged into the main board in the burner compartment behind the box cover. The black transistor may be burnt. Replace if burnt. This will happen often if the heater is connected with 220 vac power source. I highly recommend connecting to a 120 vac source if possible. The heater seems to like it more. But remember when switching power supplies to follow all manufacturers instructions on doing so. If after replacing these two items the FL-4 problem still occurs, the control board in which the conversion plug plugs into also may need replacement. This should correct the fl4 error.
Jan 05, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Hello have a HS2800 the two yellow lights are flashing....and I found a wire with a fuse in it and can't find where it plugs into...can anyone help
the wire with the fuse belongs to external light fetures (unit does not have. It was intended for future use for external ligts)
the two yellow lights endicate problme with batteries( too low) or the module controller.
3. Left motor Fault
9.Shark Module Faul
****two yellow lights*** Module problem
Sep 17, 2009 | Ctm HS-2800 Power Wheelchair
Jandy Laars Lite2 Ld 400,000 Btu Heater Logo
446 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
