Question about Brinks 3-3/4"L Marine Dial Combination Padlock 673-80001
Set the combo lock
The instructions to set the combo lock did not come with my new padlock
How do you reset the combination to a Ace Solid Brass Combination Padlocks
Open the lock, rotate the shackle180 deg, and push down.enter new combo, and rotate shackle back to normal position.
Mar 27, 2014 | Ace Hardware Ace Solid Brass Combination...
How do I make my lock lock again
Does the red indicator show ?
Is it a padlock or suitcase lock ?
It sounds like the combo has been changed.
Feb 19, 2014 | Locks & Locksmithing
I have a black dog TSA lock and can't remember the combination help
if you have forgotten the combo the only way to figure it out is to progress the combo starting from 000 and then 001,002,003,004 etc...( trying the lock at every new series until you get the correct combo. a 3 digit combo should only take about 10 to 20 minutes to solve. you can cut the time in half if you can remember the first number or the last number.
chris...
Sep 13, 2012 | Ultra Hardware Black Dog 55164 3 Digit...
Forgotten combination dial lock
hi,
on the back of some of those dial combo locks there are small numbers stamped in the back ~~ with those numbers your local locksmith shop can look up the combo for a small charge.
chris...
Sep 10, 2012 | Brinks 1-7/8 In. SS Dial Combination Lock
Lcd dislays lock padlock and none of the buttons
To Unlock the buttons, kindly follow the instructions on the Dell support page by clicking this link.
On the page which opens, scroll down to the OSD settings section.
Thanks for using FixYa.
Jul 12, 2010 | Dell E156FP 15" LCD Monitor
How do I unlock the ice-maker panel?
Press the lock again to unlock. If the second padlock is on, press and hold for 3 seconds to unlock the child lock.
Jun 28, 2010 | Bosch Evolution 800 B20CS80SNS Stainless...
On the master glo website it tells me - as a standard factory settings rule - that to open the lock i have to turn 3 times to the right to start - is that three full turns ?? could you explain how to open...
Let me see if I can help. I started out to write you an explanation when I found this video for you to watch...It explains better than I ever could.
CLICK BELOW and when you get to the site, scroll down the page on the right, till you get to " Combo Lock Training Tool " listed under " MASTER LOCK SERVICES " Click on Combo Lock Training Tool and a video will download that you can watch.
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
http://www.masterlock.com/residential/schoolcampus/glo.shtml
Nov 25, 2009 | Locks & Locksmithing
Brinks 3-3/4"L Marine Dial Combination Padlock 673-80001 Logo
56 people viewed this question
Top Brinks Locks & Locksmithing Experts
john h
andrewcahoon
Are you a Brinks Lock and Locksmithing Expert? Answer questions, earn points and help others
