Question about Samsung Galaxy Tab 2 7.0
How to removed the battery from the samsung tab 2
Will not turn on
try removing battery and then reboot
does your battery take a charge?
Jun 28, 2015 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
How do i replace the battery
since samsung galaxy tab is come with non removable battery, you cannnot change or remove its battery. If you battery get damaged or weak you can get it chnaged at your nearest samsung mobile service centre. Thanks
Dec 06, 2014 | Samsung Tab Tablets & eReaders
How to remove battery from samsung tablet
Samsung Galaxy Tab 10 1 Battery Replacement
you can see the complete guide with screenshots here....and iam sending u d video links that may help u.... How to Replace Your Samsung Galaxy Tab 3 8 0 Battery
Oct 25, 2014 | Tablets & eReaders
My tablet won't turn on
What is the brand name of your tablet?samsung tablets are easy to disemble. For tab 1 & tab 2 remove the back cover of the tab...do it gently otherwise you could just break it...now just remove the battery pin which is connected to pcb...if you have booster then boost up the battery then put back in tab & try to switch on the tab if doesnt turn on insert charger into port then wait for 2-3mins
Sep 07, 2014 | Tablets & eReaders
Hoe to change galaxy tab batery
I do not believe it is all that easy to take the back cover off. Depending on which model of the tablet you have you need special tools. A plastic picnic knife might be helpful but then there are a couple of screws to open as well.
The different models have slightly different process. See these sites.
Samsung Galaxy Tab Battery Replacement
Samsung Galaxy Tab 2 7 0 Battery Replacement
Sep 02, 2014 | Samsung Galaxy Tab Tablet PC
How do I change the battery on a samsung galaxy 2 tablet 7.0
I had found on YouTube how to change my battery. Go to you tube
And type in How to change battery in Samsung tablet. Read good video.
Jul 10, 2014 | Samsung Galaxy Tab Tablet PC
To many patten attempts
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
Feb 10, 2014 | Samsung Galaxy Tab 2 7" 8GB Android Tablet...
Galaxy tab 10.1 frozen
Remove the battery and memory card, wait 60 seconds for the processor to reset, and power up.
Jul 11, 2012 | Samsung Galaxy Tab 2
Samsung Galaxy Tab 2 7.0 Logo
20 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
