Question about Kitchen Appliances - Others
Code 160 hd17282u/06 - Kitchen Appliances - Others
Error code 160 HD17282U/06
You are being told the problem by the error code you will need the manual / instructions to find out what it is .
Apr 21, 2014 | Kitchen Ranges
Hello I have a 06 Ford freestar I'm getting a
The cooling system may be low on fluid.
The code is for a temp sensor high voltage which could be a wiring problem or something else.
The sensor needs to be in contact with liquid coolant to work. The computer is not getting an acceptable signal from the sensor, so the check engine light is on and the fan runs for safety. The sensor for the computer is different than the one for the temp gauge.
Jul 24, 2012 | Cars & Trucks
2001 honda civic ex starts dies no power
i had the same problem with my ek civic it turned out to be the crank angle/position sensor so i would replace it and try starting it then it should run
Jun 26, 2012 | 2001 Honda Civic
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
My 06 buick terraza says ' reduced engine power',
You want more than a standard code reader!! This way too simple tool fools many people because it doesnt give you all the answers! It wont show "pending" codes, trans codes, or most ABS codes!! The two problems together would lead me to believe that you might have a vehicle speed sensor problem...however, the two messages might not be related at all. What is happening is that the computer system is seeing a major flaw in the sensor feedback from one of the major drivetrain management systems and it has put your car in "limp mode" to avoid damaging the engine. This is a factory failsafe built in to newer cars. Take the car to a good local small shop and they should have a proper diag in short order! If you have a proper diag you at least will know what the risk of continuing to drive will be if you can't afford the work right now!
Jan 03, 2012 | 2006 Buick Terraza
What is 06 code on a calypso washer
could this be an OB code? if so it is an off balance code meaning the wash load is to unbalanced.open the lid redistribute the load and start it back up. all of the manuals for the calypso do not show any numbers or an 06
Nov 15, 2011 | Kenmore Elite 45986 Front Load Washer
Radio code for 2006 hyundai tucson city
get the radio out, find the swerial number
(is on a sticker on top of the radio)
write the last 4 numbers down
example: 2 5 7 8
ad 1 2 1 2
makes 3 7 8 0
3780 is your radio code.
Nov 04, 2011 | 2006 Hyundai Tucson
06 corolla dead in driveway code po607
Just get a refund. The computers are expensive and if it died in 5 days, there had to be a problem that the previous owner knew about. GIVE IT BACK QUICK befor more problems occur!
Jun 29, 2009 | 2006 Toyota Corolla
Codes for ntl starview - 7 may o9
try these they worked for me 00=5C 2C 26 36 CF 81 AB 66 01=2C 10 35 AC 06 57 BE 6F
May 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
Kitchen Appliances - Others Logo
15 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
