Question about GE PFE29PSDSS 29 cu. ft. French Door Refrigerator with Spillproof Glass Shelves, Gallon Door StoraHumidity Controlled Crispers, Drop-Down Tray and Auto-Fill Ice/Water Dispenser
GE pfe29psdss water dispenser sticking
When water dispenser is activated (by press actuator), dispenser remains "stuck" and continues dispensing water.
Have a ge profile refrigerator went completely dead,repair man replaced mother board and control panel still not working, fridge is only 14 months
If there is no power after the repair man replaced the board and panel, the repair job is not complete. Have the repair man finish the job.
May 03, 2016 | GE PFE29PSDSS 29 cu. ft. French Door...
Why does oil leak at the bottom of the Gibson refrigerator door
Hello Susan;
My name is Peter. I am a retired field service refrigeration technician.
You do not have any oil in your system with the exception of a few ounces in the bottom of your compressor. This is not your problem.
You have a water leak. The water will run across the bottom coils and the floor. By the time it reaches the front of your unit it looks oily.
Pull you unit out. Make sure you raise the leveling screws in the front first.
Remove the lower back cover. There are a few screws holing it on.
1.) Inspect the drain pan. Is it leaking?
2.) Inspect the water shut off valve. Is it leaking.
3.) Inspect the plastic tubing to your water filter, ice maker and water dispenser. Plastic tubing will dry rot and crack over time due to the heat.
4.) Have someone press your water dispenser while you observe for leaks in the back.
Feb 26, 2015 | Electrolux Frigidaire Tappan Gibson...
Take PFE29PS out of demo mode
Hold the lock and precise fill buttons for several seconds and a prompt will appear to disable it.
Sep 17, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
Ge profile refrigerator temperature setting
Sounds like the damper controller is stuck due to obstruction or isn't working at all and needs replaced.
Jul 31, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
Why are the cubes not breaking apart when dumping from the tray?
It is over-filling and the cubes are fused together... If the fill is adjustable, lower it, but you may need a new water valve... Frigidaire Water Inlet Valve 242252702
Jul 31, 2014 | Frigidaire FFSC2323LS 22.6 Cu. Ft....
Water dispenser leaking dispenses ok, but does not always shut off fully resulting in a slow drip. Like a dripping tap might be just a washer?
you have a faulty water valved solenoid. when you actuate the water lever, the solenoid opens, to allow water flow, then closes to stop it. When you continue to get a dripping before or after, its because the solenoid is not closing completely. Only resolution is to replace the water valve.
Mar 26, 2010 | Freezers
Refrigerator not dispensing water or ice
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
Apr 29, 2017 | Maytag Freezers
Not pumping water to icemaker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 08, 2009 | GE Freezers
Our water dispenser wont stop runing when we get water.
did u just change a filter?..must bleed air out of system. if not then switch at door is sticking or valve at back at supply is sticking to bleed air just run water into large pitcher till all air is out.
Jun 11, 2009 | Freezers
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
GE PFE29PSDSS 29 cu. ft. French Door Refrigerator with Spillproof Glass Shelves, Gallon Door StoraHumidity Controlled Crispers, Drop-Down Tray and Auto-Fill Ice/Water Dispenser Logo
235 people viewed this question
Top GE Freezers Experts
christian nielsen
John Tripp
John Tripp
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
