Question about Pentair Kreepy Krauly Prowler 820 Robotic Pool Cleaner - 360031
Kreepy Krauly 820 power supply blinks when plugged in but no power then
  • Stuart Doherty
    Stuart Doherty Sep 19, 2016
    Any answer here? We saw the same issue a few days age but it seems to be gone now.
Why is the indicator light blinking?
Hello! If the charger is plugged in for 12-14 hours or longer the indicator light may begin to blink. Try unplugging if for a few minutes.
Sep 06, 2014 | Dirt Devil M0896RED Quick Power Cordless...
Is it a power failure or is the TNPA5335 board faulty?
As there is LED blinks, the power board is funtioning; and 5V rail is OK. The start-up voltage, that have to come from the main board doesn't. Check for the reason. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
In most cases, the main board might have to be replaced. If so, a firmware update too might be necessary.
Jul 08, 2014 | Panasonic Test Tool Part Tzsc09187
My Gw9500 won't climb all walls in my pool
get one of your kids to do it by hand. Those things never do anything except destroy your pool and income.
Jun 10, 2014 | Pentair Kreepy Krauly Great White GW9500
My vt999 wont work the blue and red lights just blink
you have either a mechanism jammed or something wrong in the power supply bad--don't keep trying as sooner or later you will have smoke.
Dec 22, 2012 | Behringer VT999 Vintage Tube Pedal
When plugged in the hose light blinks
My spotbot lights would blink and it, for a time, only worked on deep clean even after unplugging and plugging back in. Finally it wouldn't work at all, only the hose light would blink. I unplugged the hose and plugged it back in and the machine started working as it should.
Apr 10, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
What is the wattage onroomba 560
The power supply isn't a transformer, its a switching power supply. The power supply is different for different locations, but you should not plug a 110V only power supply into a 220v source or vice-versa. You should contact iRobot if you wish to obtain the correct power supply for another location or to determine if they have an autosensing model that can sense and adapt to either 110v or 220v. You can also use a step down transformer to convert from 220v to 110v. The charger should be using 20W or less, but it will be pulling the current in narrow surges from the peaks of the voltage wave (aka a high 3rd harmomic current) and you will need to use a 40W or larger transformer to avoid unexpectedly overheating the transformer core.
Aug 25, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba Docking Station
Probably not, unless you just have to have the docking station. My roomba always had trouble mating with my docking station so I never used it. I just plugged it directly in to will using the AC adapter.
Oct 29, 2008 | Roomba Robotic Floor Bagless Vacuum
Pentair Kreepy Krauly Prowler 820 Robotic Pool Cleaner - 360031 Logo
105 people viewed this question
Top Pentair Vacuums Experts
Are you a Pentair Vacuum Expert? Answer questions, earn points and help others
