Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riding mower, 21hp B&S starts and dies
Fresh out of the garage, mower will start and make about a lap around the yard. Then, with no warning, the engine will die. The last time I mowed, after doing this, it simply started up again and ran like a champ (as usual).
Today, after the same issue, it wouldn't start at all after it died. I went inside to research, went back out, and it started back up, only to die again about a minute later. After having pushed it back into the garage and taking time to do more research, when I go back out, the engine will start and run for about 1 second with full 'choke'.
There is strong fuel flow from the fuel filter upstream of the carb, between the fuel tank and carb. This I can guarantee.
Any suggestions?
  • steve792 Jun 20, 2009
    This is the 6th or seventh time I have had it out of the garage this year, even though I live in an area of the US that might be considered by most to have two seasons--winter and road repair.
    After making this post, I went back out, took the fuel line off at the carb (on the very unlikely chance that the fuel intake at the carb had debris in it, which it didn't). After putting the fuel line back on, it started right up.
    Ok, it was running, and ran some more, so I started mowing. 20 minutes later (and, of course, 85% through the lawn), blamo, dead again. Same symptoms--every once in a while, she will actually fire, but only for about a second. Most of the time, it just turns over.
    I will go get a carb kit tomorrow, should I be able to find one, but the mower isn't that old, and the fuel has been drained every season when not in use.
  • steve792 Jul 02, 2009
    Ok, I pulled the carb, and cleaned it (though it didn't need it). While doing so, I resisted all urges to put an air filter and exhaust in to allow it to breathe more and rejet before putting it back together. ;-)
    After getting it back together, she ran for a while, but still wasn't right, dying suddenly at times, and not wanting to start again.
    I started thinking more about the symptoms, and how they appeared to be associated somewhat with vibration, so I checked the plug that goes to the solenoid at the bottom of the carb. Unplugged and plugged that in a couple of times to make sure it was seated, and noticed that the ground wire (black) was up against the engine block. Thinking that the heat couldn't be good for the wire insulation, I figured I would move it out of contact.
    And then, finally, when I went to do this, I discovered that the bolt holding the ground to the engine block was loose. Tightened that up to secure the ground, started her up, and VROOM!
    I appreciate, sincerely, the suggestions and assistance. I guess adding checking that connection (or adding some locktite, which I will be doing) is another step in the solution.
    Thanks!
    Steve
Try removing fuel bowl under carb and cleaning it. Junk and condensation can collect there. I had same problem. Did that and problem fixed.
Posted on Jun 20, 2009
    Scholar:
  • 81 Answers
Fresh out of the garage says to me this is the first time you have used it this year. There is not a very long shelf life on gasoline anymore. Plus with all the additive they put in gasoline the diaphgram in the carb could have become tough and not very pliable. Kind of like paper. If this is the case have the carb cleaned and rebuilt (as in diaphragm replaced, probably needle and seat also.) Hopefully this will solve the problem.
Posted on Jun 19, 2009
Why does it backfire on warm restarts?
readjust the valve clearances
B& S engines are renowned for stretching the valve stems during use
creates hard /no starting when hot
check for coil wire touching the engine and shorting out
Nov 14, 2015 | Craftsman 42 In. 21Hp Briggs & Stratton...
I have new battery and new starter,engine turns over but stops at a certain point and will not start, oil level and fuel level is good
remove the spark plug and crank it .if it spins real good then put plug back and try it . . last year mine bent an intake push rod .
Aug 22, 2015 | Craftsman 46" 21hp Briggs & Stratton Turn...
Craftsman riding mower - rough idle now won't start 917.258524
check and see if the float in the carb. is stuck.
Apr 15, 2017 | Craftsman Garden
Smoke coming from the bottem
your belts are slipping on the pully's and yes it would be a good idea to have it serviced at your favorite small engine repair shop...good luck
Apr 10, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Intek engine runs poorly under load and when warm
if you have a ohv ajust valves and you might have to rebuild carb.
Jul 18, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Starting Craftsman model 917.270430 riding mower.
There's a safety shut-off switch below the seat, so when you're seated the switch is engaged. If you were to fall off the mower, the engine and Blades stop (safety feature).
Check the switch to see if it's operational.
Beyond that, mower may need a tune up or servicing, if it is not starting.
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
662 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
