Question about Garden
Flymo lawnchief cuts out under load - Garden
2 Suggested Answers
  • 26 Answers
SOURCE: Where doe sthe oil go in a flymo 400 lawnchief lawn mower
the same place you check the oil the dip stick tube. you may need a funnel. after putting some oil in wait about a minute to let the oil get all the way in then check to see if you have it full.
Posted on Jul 30, 2009
Cut through cable on flymo how do i rewire
it best to get a waterproof cable connector then you do not have to take the flymo apart.
Apr 10, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
Trying to revive my old petrol mower. Its a Lawnchief 420 and I dont have the manual. Can anyone suggest how I may get a manual please? I have contacted Flymo who apparently used to make them but they...
I think your best bet would be to not look at the name of the mower as much as the name of the engine manufactureer. If B&S or Tecemsah you should have no problem. I would suggest that you go to your local library and look up the info you need. When you find you can not only study your info there ,but you can copy any part of referance book you may need. Yes you can also go online, find, study, and print up on your printer what you may need. GOOD LUCK.
Sep 26, 2011 | Garden
Where is the cutting adjustmant for blade on flymo glidemaster 340
The adjustment is done by putting spacers under the blade, you can put up to 3 spacers in, the part no. for the spacer is 513811001
May 05, 2011 | Garden
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
Flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
Jul 23, 2010 | Garden
Jul 29, 2009 | Garden
Lack of information before purchase
Hi. I think I can put your mind at rest.  I work in a Flymo service agency. The Flymo Contour Cordless Power Plus has a guide wheel for accurate edging but, in common with all other Flymo edgers and trimmers, the actual cutting is done by a whirling thin (1.5mm) plastic cord that is designed to wear out and is fed from a replaceable reel under the cutter shield.  The only risk in cutting up to stone, concrete or other hard material is rapid wear of the plastic cord.  Unless your step is made of exceptionally soft stone there is no reason to think that the step will be damaged at all.
Good luck.  If this helps, please rate my response.
Apr 14, 2009 | Vacuums
Flymo micro lite - cutting height of blade
you twist the plate holding the blades and it will lift off, then you turn the blade plate upside down and replace making sure you align the notches and then twist to lock into place. hope this helps
Oct 16, 2008 | Garden
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
