Question about Cooktops
Random beeping on clhb 20 ne hob
Random beeping on a clhb 20 ne cooke & lewis hob
How can I unlock the hob
To unlock the hob on your cook top press and hold for about 5
seconds and that should unlock your cook top.
Mar 08, 2017 | Cooktops
Hob light up.
I take it the two fuses you mention were the house fusebox and the fuse in the outlet in your kitchen? If you know the mains is getting to the hob and nothing at all is lighting up on the panel then this sounds like a job for the professionals. I can't find any mention of a reset button or user acessable fuse in the manual. The only thing left to do is check the main wire connection underneath the hob - if it is accessable. (switch off at the wall first!) Assuming you are in the UK Service force telephone number is 08705 929 929 Hope this helps.
Sep 29, 2007 | AEG 23 in. 67600KF-N Electric Cooktop
Hi I have a Samsung ceramic hob that when I have the oven on and cooking veg in saucepans it cuts out randomly displaying SE flashing I'm guessing its overheating but how can I fix this ? It makes
An SE error message on the display of a Samsung ceramic hob means the control panel sensor has been on for too long.
There are a few reasons why the sensor could be saying it's been on for too long:
  • Touching the key area for more than 10 seconds.
  • Leaving a wet cloth on the touch key area.
  • Spilling a liquid on the key area.
  • By touching 2 or more keys together. All of these can be fixed by turning the hob power off at the wall, then back on again.
Jan 30, 2018 | Cooktops
My John Lewis ceramic hob is locked and comes up with error code E R 0 3. I think the product code is JLBICH 602 ?? Please can someone help.....I'm starving!!!
press the two left buttons at the same time to reset or the two right buttons to reset if it doesnt work try oxfam
Feb 23, 2012 | Cooktops
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
My soup spilled over on to my whirlpool ceran cooktop and i cant get the stains off. Is there a way to do it?
Is this a ceramic hob? If it is, you will need a ceramic hob cleaner (john lewis does one) OR Astonish oven/pan cleaner, a non-scratch washing-up sponge and a fair amount of elbow grease. This works for me.
Oct 05, 2009 | Whirlpool RCS3014 Electric Cooktop
Electrolux insight cooker EKT6045 problem with hob controls
i have an electrolux model ekt 6045 it does not stay on it comes on for 1sec then goes off wot would be the cours of this please the oven stays on but the hob doesent thank you.
Aug 11, 2009 | Electrolux Cooktops
Candy sprinter
Great.. finally. i manage find from solution from user guide.. L is Locked. below is the instruction. will check out tonight.
The locking function holds the current settings, or prevents anyone from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on. To lock the hob : -Press the on/off button     . -Press simultaneously " - " button and " + " button of the front right zone (PVD 633 front left zone), and then press again on the " + " button of this zone. The hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds. To unlock the hob : -Press the on/off button      . The locking indicator " L " is displayed on all zones. -Press simultaneously the " - " button and the " + " button of the front right zone (PVD 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Jun 24, 2008 | Cooktops
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Cooktops Logo
70 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
