Question about Kenmore 62602 Electric Dryer
How do i change the heating element in my dryer
How do i change the heating element in my frigidaire/electrolux clothes dryer
    Genius:
  • 1,122 Answers
It's way to hard afor a lay person,call for repair-mike
Posted on Jun 19, 2009
Frigidaire Electrolux aeq6000es1 heats but sometimes doesn't heat when drying clothes why is this happening
Hello friend, thank you for your inquiry!
I understand that your Frigidaire dryer heats and will occasionally not heat when drying the cloths. This could be a possible issue with your thermostat or control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord from it for at least ten minutes. If that does not help resolve your issue you may need to have a professional technician out to perform a proper diagnosis and repair. This will help your avoid any unnecessary part purchases. -Matt
Dec 28, 2015 | Frigidaire Dryers
How to replace heating element on frigidaire fase7073lao dryer?
Takes Frigidaire (OEM) Part #134792700
http://www.ebay.com/itm/134792700-NEW-Genuine-Electrolux-Frigidaire-Kenmore-Dryer-Heating-Element-OEM-/181461935813?pt=LH_DefaultDomain_0&hash=item2a3ff966c5
~ $87 w/free shipping
Here's more pix on YouTube. Get your screwdriver out and go at it. You'll never learn any younger. Write down and/or label where EACH wire goes as you disassemble. Just remember SAFETY FIRST. NO POWER while you're working on this ! UNPLUG is enough, there is no residual voltage on a dryer. Best help may be on YouTube. ask for (type in) Frigidaire Electric Dryer repair. There are several videos, one of which should serve to give you courage and a starting point if you've never done it before.
Jul 20, 2014 | Dryers
Dryer won't heat clothes
Heating element is either unhooked or needs to be replaced
Nov 29, 2013 | Frigidaire FER211A Electric Dryer
HOW DO I CHANGE HEATING ELEMENT ON MY ELECTROLUX DRYER?
You might try this step by step process. It is not for Electrolux, but the process should be similar. Changing the Heating Element
Apr 08, 2013 | Electrolux EIED55HMB Electric Front Load...
IT WILL NOT HEAT. how do i remove the heating element to replace
Is it gas or electric? It could have a bad timer, heating element, power problem, circuit breaker could have tripped, or blown fuse or burnt wires inside dryer. I believe the top pops off from inserting a screw driver between the top and front dryer frame and pushing in 2 clamps located near each side. Then the front unscrews from the inside. Or a bottom panel might come off same way underneath the door.
Sep 16, 2009 | Dryers
Dryer has no heat
either your heating element or your thermostats are bad. on the heating element casing there are two thermostats. check the top one for continueity if it doesn't have continueity the change both thermostats. if they are good then check your heating element for continueity. after you get your dryer heating then clean out your vent system... if it's not venting properly then your dryer will take a long time to dry.
Jun 16, 2009 | Frigidaire Dryers
No heat when drying clothes. Where is the fuses on a dryer
There are two thermal fuses, but if the fuse has gone - there will be another fault Replacing them without sorting the fault will only lead to them going again.
Fuses will blow if -
  1. The fan motor stops working
  2. The vents are blocked
  3. The heating element overheats
  4. There is an electrical fault
These need checking first.
The fuses are usually clipped into a metal frame over the heater coil - which is on the top of the drum.
Disconnect the machine and remove the top cover to see them.
Look for a picture of replacements online so you know what to look for.
Jan 10, 2009 | Frigidaire FEQ1442ES Electric Dryer
Tumble Drier does not heat - Its a white knight. What would be the likely cause and is it repairable?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Nov 01, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
178 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
