Question about Garden
Manual for pc40 chainsaw - Garden
Where can i get a users manual from for the pc40 chainsaw
Hi Michaela:
Chain saw manuals can be quite similar.
Here's a link to an excellent one that should give you most of the information that you need.
http://www.oregonproducts.com/pro/pdf/maintenance_manual/ms_manual.pdf
Cheerfuls.
Oct 19, 2015 | Garden
Todd PC30B schematic
http://www.electronicspoint.com/rv-power-converter-todd-pc40-insulator-problem-t46674.html
Aug 14, 2014 | Computers & Internet
Where ?
Hi this should be a good link:
http://www.einhelltools.co.uk/pdfs/store/728.pdf
First two/three pages are in german, then the Qualcast manual is below :-)
May 13, 2014 | Garden
Chain replacement on qualcast pc40 chainsaw
Follow the instruction in owners manual page 8 click link belowchain replacement
click here page 8
Nov 20, 2013 | Garden
Qualcast petrol chainsaw manual Pc40
where can i get a manual for my qualcast pc40 chainsaw
Jul 27, 2013 | Garden
Lost the slew on a kamatsu pc40
Check that the key in the drive gear is not sheared in half. check that by trying to slew and see if the drive motor is working. The hydraulic motor may be seized up
Mar 19, 2013 | Joal 1/32 Komatsu PC 450 LC-6 Excavator
POWERCRAFT PC40-38cc.THE CHAIN OILER DOES NOT APPEAR TO BE WORKING! NO OIL IS COMING OUT THE SMALL HOLE IN THE HOUSING THAT THE BAR IS CLAMPED AGAINST, WHEN I RUN THE ENGINE WITH NO BAR AND CHAIN...
It would appear that you must 'go under the cover'. Look for a damaged oil line or split oil tank. The oil pump may have come loose from it's mounting. Be sure to check the oil filter for plugging. Hope this helps!
Dec 21, 2010 | Garden
Powercraft pc40-38cc chain oil not getting to chain manual is lost is there a simple fix?
Take the bar and chain off. Clean the engine area where the bar fits to and start the engine--oil should ooze out of the small port where you cleaned. If ok, clean the small drive-end oil passages that lead from the larger holes out to the chain groove on each side of the bar. They commonly fill with sawdust and dirt which plugs them. Clean the entire chain groove and check/oil the end sprocket if it has one. Reinstall the bar and chain, then start the engine and run the tip near some cardboard for a few moments--it should throw off a thin line of oil. Hope this helps!
Oct 17, 2010 | Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
