Question about Vehicle Parts & Accessories
I have an Ungo remote car starter ID=EZSDEI474V. When I start the car, I have to press one of the buttoms on the remote starter to shut a tic, tic, off. Then, when I go to start the car, it won't start. Is there a way I can disconnect the remote starter?
4 Suggested Answers
MECP Guy
  • 344 Answers
SOURCE: I need to find an installation diagram for a 2001
www.bulldogsecurity.com
Posted on Jan 08, 2010
  • 132 Answers
SOURCE: Lost my remote viper remote
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Posted on Oct 15, 2011
  • 1082 Answers
SOURCE: remote starter won't turn air conditioner on eventhough it is turned on
Go back to the installer to fix it. This needs a knolegable professional.
Posted on Aug 26, 2012
Car won't turn on; clicking sound
It does sound like a starter problem but the easiest way to rule that out is by trying to jump start the car with a push , if your starting motor has packed in it will still start with a jump start
Feb 24, 2013 | 2008 Hyundai Elantra
I have an ungo remote start/alarm. This AM the car would not start and the alarm went haywire- kept going off, took control of the car, A/C going on and off, etc. Had to disconnect the battery to get it to...
i have a ungo sr 6000 i missed placed my lcd 2-way remote so i only have the secondary 4- button remote. How can i disable the timer auto start!!!!!!!!! PLEASE HELP ASAP !!!!!!!!! GOIN BROKE ON WASTED GASSS!!!!!!!!!!!!!!
Jul 30, 2010 | Ungo SR6000 2 Way Security with Remote...
Clarion ungo alarm model 5100
Can't seem to locate a manual. Just get into the wiring under the dash and follow the larger wires from the alarm brain and cut each wire, one at a time, from the factory ignition harness them tape. Start with just the starter wire to see if that fixes the issue for now. If this problem just started, check to see if there is a tach wire that runs under the hood to a coil or injector. If this wire is disconnected the remote start won't see the car is started and will continue to crank the starter.
Nov 03, 2009 | Ungo S670 Car Alarm 2way LCD & 4butt Rem
Program Optoma EP-739 remote to Bell Express Vue 3100 remote
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Feb 23, 2009 | Optoma EP739 Multimedia Projector
I have a bell express vu remote that i am trying to get to work with one of your tv's. the remote is a 3.2IR the model number of the tv is 20pt634v37or 2opt634v37 can u please help me figure out wut the...
5-Press record
Finish :)
Jan 06, 2009 | Directed 434MHZ Remote Control
Remote codes
5-Press record
Jan 03, 2009 | Bell SH50102 Remote Control
CAR WONT START ON FORD FALCON AU (AUTO)
Check the voltage on your battery. When the battery is low, you will still have lights and what not but not enough juice to start the car. Check the condition of your battery cables especially your ground. If everything check out fine, your problem may be a bad starter or the solenoid. If you replace the starter, replace the solenoid with it. Be sure to check the cable from the starter solenoid to the starter.
Sep 25, 2008 | 1994 Ford Taurus
Vehicle Parts & Accessories Logo
24 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
