Question about Razor MX500 Dirt Rocket
I cant find a diagram for the wires on the battaries
  • 241 Answers
I attempted a direct soundcard to amp to speaker/sub setup, but that didn't work out too well. Now I'm just using the inputs on my head unit, whenever I rev the engine the whine gets worse. I directly run 14awg wires from the battery's +12 and ground, and I'm using the ground on the harness. There is no whine when I play dvd's or mp3 from the head unit, but when i switch over to aux-in thats when the whine starts. I've checked to see if it was the audio in on the head unit that was causing the trouble using portable cd and mp3 players. My amp is turned off via fog light switch for test purposes.
Something interesting I found was when I tap the 1/8 plug onto any metal part of the faceplate it makes the same exact sound, but when I completely cut off power/ground from the comp, the buzzing goes away when I tap the faceplate.
Moving the mouse also increases the noise...
This is a good replica of the wiring diagram in my car at the moment, the layout is as pretty close to how it is in my Rsx. Attached images i cant find a diagram for the wires on the - 29633d1148447221-complete-diagram-wiring-cant-find-problem-diagram.jpg
Posted on Jun 22, 2009
Connecting battaries for a Rascal Autogo
When you put the second battery in the case paying attention to polarity position, the longer wire will go to the top connector. If you have a voltmeter you can identify which wire has 12 volts on it. It should be the brown wire but verify anyway. This wire has to be connected to the NEGATIVE terminal of the second battery in order to get 24 volts to the scooter. The remaining wire connects to the positive terminal of the battery.
May 04, 2017 | Cars & Trucks
Cant get tractor to crank
Check simple things first, is the battary good, are the conections on the battary tight, is the deck engaged, are you sitting firmly in the seat, have you fully depressed the clutch/brake pedal, the last three items are to make sure the saftey switches are dissabled
Feb 14, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Scanner was working fine changed battarys and now only workes when pluged in also changed the battarys again no luck
hello remove the back panel and check the power lead going to battery compartment ,make sure batteries a installed correctly ,check the battery terminals in the compartment make sure there are no wires broken or have come loose
Feb 21, 2011 | Uniden BC80XLT Handheld Scanner
Cant find wiring diagram
Hi and welcome to the site,
For the wiring diagram of a Kawasaki GPZ / ZX 400, please click here.
Good luck and thank you for asking.
Jun 06, 2010 | 1988 kawasaki ZX 400
I have a big problim with mt 91 honda accord my battary wount charge i put new altanater new battary all cables are great but it wount seem to charge the battary if i charge the battary it well last up to...
With the engine running are you getting any voltage off the alternator? check with a multimeter. Check voltage at battery while running should be 13 volts or more.
May 16, 2010 | 1991 Honda Accord
Radio won't turn off and is still engaged.Could flatten battary.
with a pioneer stereo you have to wire it exactly rite one of the wires draws power from your battery, and the other through your ignition to your battery, look up the wiring diagram on your car, you may just have wires backwards, mine had the same problem, but mine was unfixable due to the fact its a cobalt
Jan 07, 2010 | Car Audio & Video
NO MENU SHOWN
The only way to reset your phone is by pressing the center button key (in the middle of the navigation keys) while turning the phone on.
Dec 27, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Negative battary cable where do i connect it to from battary to ?
it should ground to the block or frame. can you follow the old wire?
Jun 06, 2009 | 1994 Hyundai Sonata
Wiring installation on Majestic amplifier total 60watts 2x30 model# ma-60
To install the amp you need a amp wiring kit they range from $15 and up depends on how many watts u have.Once you have the wiring kit start with the ground wire it needs to be no longer then 24 inches long the shorter the better find a good ground in the trunk or where ever you want to install the amp make sure its metal to metal no plastic paint or any other debrie is in the way of the metal.If you can't find a paint free surface all you will need to do to fix this is sand off some of the paint and then ground the amp.The ground wire needs to be connected to the amp before any other wire once you have the ground connected then connect the battary wire make sure you have the right size inline fuse on the battary wire that also depends on the watts of the amp.once you have those 2 wires connected then u will need to pull the stereo out of the dash and hook up the remote wire to the power antanna wire if you have a factory car stereo and don't have a power antanna you can try one of these solutions 1st one Run the remote wire from the battary wire on the amp and use a toggle switch between the remote and battary wire or you can run the remote wire from the amp to the fuse box of the car and hook it up to a fuse that only works when the key is turned on.Once you have all this hooked up its time to hook up the subs/speakers on the amp it should indicate if its bridgable it will show lines from one positive and one negative and at the top of the lines it will say bridge but if not the just connect the speakers positive to positve and negative to negative.If it is a bridgeable amp i would only recommend hooking it up bridged if you are hook up subs if you are using 6x9's on the amp you don't need to bridge the amp.If u have any more ?'s just ask i can help with this i've done this alot.
Sep 03, 2008 | Car Audio & Video
Re: mobile
take the phone to a mobile servioce center and have them try to service the phone for you.
Apr 05, 2008 | Sony Ericsson K750i Cellular Phone
Razor MX500 Dirt Rocket Logo
314 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
