Question about Frigidaire FAFW3801LW Front Load Washer FAFW3801LW
Frigidaire stuck pump - Frigidaire FAFW3801LW Front Load Washer FAFW3801LW
  • Frigidaire Master
  • 5,323 Answers
PROPELLER OBSTRUCTION? REMOVE AND HAVE A CLOSE LOOK AT IT U MAY BE ABLE TO REMOVE WHATEVER ITEMS IS PLUGGING IT
Posted on Mar 31, 2015
Have a frigidaire,fdb520rhso.run full cycle but will not drain.ci checked hoses and is open.could a valve be stuck?
Do you hear some noise from the drain pump? Check the pump if you have power there, if not, then the circuit board is at fault
Mar 24, 2013 | Frigidaire FDB520RH Builtin Dishwasher
Frigidaire E20
Error E20? Your washer's drain pump maybe clogged/something maybe stuck on it!Have it checked out before you use it again.
Hope this helps.Thanks!
Dec 24, 2011 | Frigidaire Washing Machines
Frigidaire washer stopped at rinse and makes humming noise
something stuck in pump find filter and heck refer to manual
Sep 28, 2009 | Frigidaire ATF6000ES Front Load Washer
I have frigidaire FWT449GFSI,the water can cont come out
HI, check the following to address this issue.
1. Clogged drain line or water pump Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Sep 23, 2009 | Frigidaire ATF6000ES Front Load Washer
WE have a Frigidaire top loader about 4 - 5 years old, and it went into a spin cycle with the tub full of water. any ideas? It threw water everywhere. I'm thinking stuck contacts on timer.
sounds more like you have something stuck in the drain pump or drain hose. use a shop vac and attach it to the end of the drain hose and see how easy or hard the water comes out.
if it comes out easy possible small object stuck in the pump. if the water comes out slow or none at all there is a piece of clothing or something in the drain hose that comes from the bottom of the tub to the drain pump
Sep 21, 2009 | Frigidaire Washing Machines
Error 20, won't rinse and spin
This is an indication that something is stuck in the pump, preventing it from draining properly. Remove the access panel and the pump is on the right side. After removing the hoses, you should be able to clear whatever is stuck in the pump. Re-assemble and restart the machine. Best of luck.
Greg
Jul 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Won't drain or spin
Find the pump on the battom. Make sure you get a pan, You will need this to cacht the water. Remove the hoses from the pump. Then you should be able to find the object. You may have to remove the pump. It is held on by two screws.
Jun 26, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Water isn't being pumped out. Does have power.
I assume you are referring to a drainage issue within the unit. check the following below.
2. Water Pump
May 30, 2009 | Frigidaire Washing Machines
Frigidaire Gallery trouble
Took off the front panel, opened up the hoses to the pump, found a small metal magnet from my son's pocket that had been stuck in the pump. Once it was removed, the washer worked just fine.
Nov 05, 2008 | Frigidaire GLWS1233A Top Load Washer
Frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Oct 19, 2008 | Frigidaire GLTR1670A Front Load Washer
Frigidaire FAFW3801LW Front Load Washer FAFW3801LW Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
