Question about Little Giant Vcma-15uls 554405 Vcma Series Automatic Condensate
#554405 Little Giant condensate pump not draining
Pump installed in new furnace last fall worked fine til last month. Runs extended time but draining very slowly. Have been putting white vinegar in pump holding tank regularly. Does not seem to have any residue build - up. I'm pretty handy if I know where to start.
john224
  • 1378 Answers
SOURCE: Our furnace is a six
Thank you for posting your question here on Fixya.com.
What is the problem you are having that makes you think it is the pump? The pump has nothing to do with furnace operation; it is there to remove condensate and humidification water from the furnace to a drain or sink. If the furnace is tied to the pumps secondary float to allow the pump to shut off the furnace due to high water, disconnect the switch and wire nut the two wires from the furnace together.
If you want to fix the pump, a few common problems center on lint and dust buildup in the reservoir and/or tubing. You can use compressed air to blow out the discharge line. Be careful to keep the end in a safe direction...you would be surprised who much slimy crud builds up in the tubes. You can take the top off the reservoir and clean inside it. On the coldest days, check to be sure the water is not somehow freezing within the discharge, which would only seem possible if for some reason the tubing leads outdoors.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 09, 2010
  • 560 Answers
SOURCE: Little Giant pump WGP-90-PW trips GFI circuit
You might have 2 problems. The GFIC might be wired wrong or the pump wirng might be compromised with moisture. The noise issue? Are you running this unit without submersing it? They will burn out if you do. To get a more accurate running sound, submerse it with a flexible pipe so you can run it in a 5 gal bucket without losing the water.
It's possible a bearing is burned out.
Ron
Posted on Jul 06, 2010
heatman101
  • 43501 Answers
SOURCE: My Little Giant pump (554405) is connected to our
There could be gunk in the bottom....then the float does not work right and the pump will not pump either...
remove the pipes and/or hoses and then the screws that hold down the top....clean the inside really well and reassemble... that may work,,,, but it may already be burnt up...
if cleaning does not work the replace the pump...you should be able to buy a new one at a HVAC supply house or some place like HD or Lowes...they will be in the 50.00 or less range...
Posted on Jan 11, 2011
Testimonial: "Thanks for the suggestion. I cleaned out the basin, removed gunk and it seems to be fine now. Thanks again."
dogsled48195
  • 411 Answers
SOURCE: I had a new hi-eff.
Depens on what type of humidifier you have there are tank type like lobb or water over waterover will make the pump run every time the lobb wont it has a tank with water going up in price lobb wa2 is better
Posted on Feb 27, 2011
  • 92 Answers
SOURCE: MY LITTLE GIANT PUMP IS BRAND NEW AND THE AUTO
Take it out and back, dont waste your time with a defected product. It will only cause you more work later
Posted on Sep 07, 2011
After the winter my motor runs fine but no water pressure
Did you drain the pump in the fall? Cracked housing or blown gasket.
Apr 22, 2014 | Garden
Condensate pump runs but does not pump
I have only seen a couple but they were pressed on the shaft. Superglue might work.
Dec 28, 2013 | Little Giant VCMA-15ULST, 1/50 HP, 65 GPH...
I had a new hi-eff. furnace and A/C system installed three years ago. The furnace humidifier drains into a little giant condensation pump. I just noticed that the pump cycles on and off very rapidly when...
Feb 27, 2011 | Little Giant Condensation Removal Pump...
My Little Giant pump (554405) is connected to our furnace/cac collecting condensation. It's been working fine for about 5 years. Now it keeps turning on for about 2 seconds and stopping only to repeat...
Jan 11, 2011 | Little Giant VCMA-15ULST, 1/50 HP, 65 GPH...
My old pump has the brown and blue wires connected
first do not change the factory wiring, what voltage is the pump wired for, what voltage is supplied to the pump.
then we figure out the rest
also what do the instructions say about the pump
NO stands for normally open contact-which means during operation is open which means off.
will be glad to help 865-888-1220
Mar 02, 2017 | Little Giant 115V 60Hz Condensate Removal...
Our furnace is a six year old Armstrong Ultra V high efficiency gas furnace with a Little Giant pump. We have owned the home for about 3 years. For a couple of the very coldest days each year, the furnace...
John
Jan 09, 2010 | Little Giant Plumbing
I have a york 90%+ furnace the inducer fan fills with condensation passing into the pressure switch. I have took apart the condensate pump motor cleaned it and the pan,I have blown thru all condensate...
Make sure that the drain line outside is only about 6" long it may be freezing up. Does the Condensate pump have a safety switch to kill the power if it runs over? If it does it should kill power to the heater. Make sure the drain has a fall. Check the install manual to make sure the hoses are hooked up right.
Jan 04, 2010 | Heating & Cooling
Little Giant Condensate pump runs for 1 sec when res not full
Is there a check valve in the pumps discharge fitting? If there is it may be stuck open or broken allowing some of the water to return to the reservoir once the pump shuts off which then may lead to the brief cycle between full cycles.
If there is not one, install one to keep any water from backing back into the reservoir and that should stop the short runs.
Aug 06, 2009 | Plumbing
Little Giant Vcma-15uls 554405 Vcma Series Automatic Condensate Logo
65 people viewed this question
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
