Question about Friedrich QuietMaster SM24L30 Thru-Wall/Window Air Conditioner
WHAT FILTERS CAN I USE FOR MY FRIEDRICH MODEL SM24L30-A
I working on a old Friedrich water source heat pump Model # V42 does anyone knows what size is it?
The friedrich name was taken off of units in the 80's when the climatemaster name was invented. My guess is 42000 btu or 3.5 tons rated capacity
Feb 05, 2015 | Friedrich Heating & Cooling
How to replace coolant in air conditioner...
fan motor is bad stuck or relay or capictor if fan dont pull air thru condensor it does not turn to liquid and then wont evaporate or cool in evaporator
Aug 28, 2012 | Friedrich QuietMaster SM24L30...
My Friedrich QuietMaster Series KS15L10 115V model will being to blow cold air and then after 5 to 10 minutes will trip the circuit breaker. We recently had a heat wave for about 2 weeks in which the unit...
Hello
Yes the northeast had temps that went past the limits of modern a/c.
Try cleaning the outside fins and coils.
Spray a product called simple green on the fins while unit is off.Leave on for 5 min.
Then rinse off with a hose.
This should keep your compressor running cooler.Also clean any filters in the inside unit.
Aug 03, 2011 | Friedrich QuietMaster KS15L10...
I'm looking for the accordian style panels for the friedrich qstar 06j10
Hello, here is a link to parts for your AC. http://www.searspartsdirect.com/partsdirect/part-model/Friedrich-Parts/Room-air-conditioner-Parts/Model-SQ06J10BA/3120/0904032/50024048/00002
Jun 20, 2011 | Friedrich QStar SQ06J10 Air Conditioner
Where can i buy replacement filters?
have you tried there web page?adrian,,,,,,,,
Sep 02, 2010 | Friedrich KStar KQ06J10 Air Conditioner
We have model # MW09C1E/MW12C1E indoor unit - wall mounted type Has started to leak water - not sure if it is the pump that has stopped working - we have cleaned the filters and the vents in the front...
Many do not have a pump and the drain simply plugs... blow it out with air...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Friedrich Heating & Cooling
Where can you get replacement filters for the Friedrich QStar SQ05J10B?
Not know where you live ( state) if you have a Grainer in the area, or a Home Depot, you can purchase replacement ( cut to size with support) another maybe Ace hardware or On line ( type in "air filter for A/C)
Jul 17, 2009 | Friedrich QStar SQ05J10B Air Conditioner
Friedrich QuietMaster SM24L30 Thru-Wall/Window Air Conditioner Logo
26 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
