Question about Tacsew T500
Thread keeps snapping on blind hemmer - Tacsew T500
4 Suggested Answers
  • 749 Answers
SOURCE: Blind stitch won't lock
This is hard to find in the internet so I hope this will solve your problem...
Frequently Asked Questions
Q) Help!
I am breaking a lot of needles and the tension is getting too tight on its own while stitching and causing the thread to break. I am learning the machine for two weeks. Is it so sensitive too wools, cottons, and fleece that this would make such a major difference in the stitching - breaking needles, breaking thread?
(A) It may not be tension that is causing the problem with your portable blindstitch. If you have broken needles it has probably left some needle burrs in the thread and needle path that need polishing off with fine emory cloth (crocus) before sewing again.
Start with a new LWx6T needle without thread or fabric. Watch the needle as you turn the hand wheel. If there is needle deflection, reduce the penetration dial until there is no needle movement. If there is needle deflection caused by burrs, they must be polished off. Check the looper tip and two arms for any needle burrs and polish off. If there is needle deflection caused by the needle track lifting the needle, lower the track very slightly with the screws on the side of the black metal bracket above the needle.
Finally, Back off on the tension dial and retighten while you are sewing with a light strong thread and light to medium weight fabric, until you get the correct tension without loops. If tension is too tight it will push the thread up so it is not all the way down between the tension discs where it belongs.
(Q) I can't understand how to finish off at the end. It
always unravels. I have read the manual and it seems simple but I
apparently just "don't get it." Any help would be appreciated.
(A) At the end of the blindhem seam, position the needle all the way to the left, then use the knee lift to remove the fabric and jerk on the fabric at the same time. That will tie off the tread and break the thread at the
needle without bending the needle. You can weave the thread tail back into the stitches or cut it off. Before the above procedure, you could also turn the handwheel counterclockwise for a few stitches, then come back to the end of the seam and repeat the first procedure above.
Posted on Nov 17, 2007
SOURCE: Instruction manual for the tac sew t500 blind hemmer
I was looking for a manual for my T500 as well and stumbled across this site:
http://www.allbrands.com/images2/common/MSK-588_Instructions.pdf
It is for the reliable brand but they are almost identical and it is better than nothing!
Posted on Feb 17, 2009
SOURCE: My blind hemmer is skipping stitches which then makes it possible to unravel the entire seem. What is causing this?
I would suggest changing the needle
have you ran over any pins or heavy seams?
I would suggest finding a sewing machine shop in your area that can work on
the machine. because it could be out of time,,
Posted on May 01, 2012
How I use blind hemmer stich fot
Google
"How to use a blind hemmer stitch foot"
and watch the YouTube videos...
Oct 04, 2014 | Sewing Machines
Blind hemmer is "frozen" won't move at all. What can I do?
on a normal sewing machine this usually means the threads are all snagged up in a knot in the bobbin case. Snip your threads, wriggle the fabric out, remove all snagged threads and rethread the machine. I don't know if this will work with your blind hemmer.
Apr 25, 2013 | Sewing Machines
I am having trouble with adjusting the tension on my consew 817 blind hemmer. Works on felt back lining but then I cannot get a good stitch for a polyester blend face fabric. Stitches are loose and out...
I wonder if you use a tear away interfacing if it would give it some bite. I wouldn't do too much adjusting because you do not have the training and it can really mess it up. Also, totally rethread your machine making sure that all of the guides and discs are getting the thread. Check the tension of the thread by using the flossing technique.
Nov 19, 2017 | Consew 817 Mechanical Sewing Machine
How to thread a juki serger sewing machine. i need a large diagram of how to do it. thank you
do you know what model Juki it is? Is it a serger or a sewing machine? Juki do industrial straight, serger and specialised machines such as coverstitch and blind hemmers as well as domestic sewing machines and sergers so there is a big range of machines.
There are manuals at this site for http://jukihome.com/products/mo644d.html various models of Juki Home sergers, but you will need to hunt through and find your model.
The manual is on the "features" tab for each model so just dig down a bit to locate the pdf file in there.
I hope this is what you were searching for.
Jun 03, 2011 | Juki Sewing Machines
I need a replacement pressure foot release lever for a Simplicity BH600 blind hemmer.
Supposedly, Simplicity is made for Tacony. I would start there to ask about parts.
Is this a presser foot lifter?
I do not recall ever seeing a pressure foot lifter.
Mar 04, 2010 | Simplicity Sewing Machines
Nov 24, 2008 | Tacsew T500
Blind hemmer
First get a new quality needle of the right size for your machine use a good quality hemming thread and check your tensions. If this fails to fix the problem you will probably have to have the timing checked.
Jun 06, 2008 | Sewing Machines
Tacsew t175-2 blind hemmer
http://cgi.ebay.com/blindstitch-machine_W0QQitemZ110219022538QQihZ001QQcategoryZ3118QQcmdZViewItem
only one online email this seller has has manul operters guide as him to scan it off for u or read sum of it only one i see since so old
Feb 03, 2008 | Sewing Machines
Tacsew T500 Logo
52 people viewed this question
Top Tacsew Sewing Machines Experts
Rommel Balcita
Nick Olsen
Ruth summersides
Are you a Tacsew Sewing Machine Expert? Answer questions, earn points and help others
