Question about World Dryer Corporation Home
Hand dryer timers - World Dryer Corporation Home
Hand dryer won't shut off
will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Aug 14, 2014 | Dryers
Need to know which color wire goes to which connector on the timer. frigidaire wiring diagrams
Hi garyab9ss, I appreciate your post!
It appears your inquiry is listed under Frigidaire Electric dryer and you need the wiring diagram. May I have the model number please? You can typically locate the serial tag (which lists your model number) on the upper front, as you open the door or on the right/left edge on the inside of the door. Also, please provide me the timer part number that you have in hand. With this information I can deliver the correct material to you. Thank you! - Z
Jul 28, 2014 | Frigidaire Electric Dryer
Dryer won't start
Hard to tell for sure without looking at hands on, but I think you are looking in the right direction as to it being the timer. If you know someone locally that works on appliances you could have them check it for you. Sounds like something may have come apart inside the timer or a contact came apart and it is no longer making proper contact.
Mar 16, 2014 | Dryers
The knob on the right just turns (no clicking) so it does not seem to be selecting a time. now dryer wont start.
Check your timer knob. On these GE dryers I have found a lot of times the knob cracks where the stem of the timer goes in and the resistance of the timer will make ti slip internally rather than turning the knob. If the knob appears to be ok, then I would say you definitely have a bad timer on your hands.
Timer is part number WE4M271 and runs around $100 from marcone's
Knob is
WE1M654 and is around 18$
Good ;uck with this!!
Jul 05, 2010 | GE DBXR463GDWW Gas Dryer
Timer making noise, but not moving
If timer motor is in operation but the dial not forwarding, yes the timer is faulty. plastic gears in the timer eventually ware..
Jun 09, 2010 | Amana LEA11 Dryer
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Dryer wont heat up
There could be a number of reasons why your dryer is not heating.
1) The element may be faulty
2) A thermostat or thermistor could be faulty or need resetting (if you have one with a reset button) You would need to check your hand book for this info.
3) you could have a wiring fault or lose terminal.
4) If you have a dryer with a revers tumble (one that goes in the opposit direction for a few minutes before continueing) on some models this incorperates a revers timer that works off the main timer and when it is in revers tumble the heater is switched off. If the timer is faulty it would keep the heater permanently switched off.
For more Hotpoint help click on link
Mar 18, 2010 | Roper Dryers
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Hotpoint Aquarius Tumble Dryer TDL 31
Replaced with a new unit as not cost effective to repair.
Feb 16, 2009 | Hotpoint TDC32 Electric Dryer
Home Logo
383 people viewed this question
Top World Dryer Corporation Home Experts
Donni Steen
Tom Chichester
Are you a World Dryer Corporation Home Expert? Answer questions, earn points and help others
