Question about Husqvarna Zero Turn Mower Z5426
Stopped pulling while mowing - Husqvarna Zero Turn Mower Z5426
Transmission wont pull
get a new belt or check the drive belt,it might of just come off the pulley
May 28, 2015 | Garden
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
Why does rearend stop pulling
I would suspect the drive belt first
May 19, 2014 | Murray Garden
My lawnmower stopped
Check the oil. I bet you seized the engine.
May 18, 2014 | Honda HRC216HXA Commercial Lawnmower
Mower worked great then just stopped!
mine did this once i was mowing and hit something and it died and the problem was a key pin broke. if you take off the cover and under the pull cord there is a small key pin that slides down by the shaft
i hope this helps
Dec 18, 2012 | Briggs & Stratton Garden
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Riding lawn mow
give as the model so we can help.
Apr 15, 2008 | Black & Decker 19" Electric Lawnhog...
Husqvarna Zero Turn Mower Z5426 Logo
29 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
